17.09.2024, 12:19
		Hello!
This time, as the title of the thread says, when accessing scada-main, the CPU load exceeds 100%, making it inaccessible for about 4-6 minutes, and when under high load, the event script that you want to run on logicmachine is not executed.
This problem occurs irregularly and does not occur only under certain conditions.
The same problem occurs with both local network and VPN connections.
Product information
HW: LM5 Lite (i.MX6)
SW: 20211215
I have about 10 LMs purchased around the same time, and this problem is particularly noticeable on three of them.
What do you think the cause is?
Could it be due to a hardware malfunction or a firmware bug?
This problem has not occurred with LM5 Lites purchased after June 2023, so we believe that it may be resolved by updating the firmware.
SW:20230612
For example, if I update the firmware from 20211215 to 20230612, please let me know if there are any problems that may occur.
It is difficult to revert to the original version after a problem occurs, so I would like to make a careful decision.
I look forward to your reply.
Best reggards,
Product information
SW: 20211215
SW:20230612
Best reggards,
