ZigBee library
Hi at all,
I'm studying the ZigBee library, because I have a problem with a ZigBee device (his firmware it is bagged). The device sends status if the CMD arrives from LM but if I made changed in local, it doesn't send messages.
If I press the read command on the ZigBee interface status arrive. (See attached picture)
Here my request, is it possible by script simulate the pressing of that button?
Or which is the function in the library to request the device status?
Best regards Cristian
Full status read is done in the user UI part so it cannot be called from scripts. You can read attributes like LocalTemperature via a script:
zb = require('applibs.zigbee')
addr = '0123456789abcdef'
cluster = 0x0201 -- HvacThermostat
attrs = { 'LocalTemperature' }
res, err = zb.cmdsync('getnamedattributes', addr, cluster, attrs)
log(res, err)
if type(res) == 'table' and res.LocalTemperature then
  temperature = res.LocalTemperature / 100
  log(temperature)
(13.09.2023, 10:57)CristianAgata Wrote: Hi at all,
Thank you so much
(13.09.2023, 11:56)admin Wrote: Full status read is done in the user UI part so it cannot be called from scripts. You can read attributes like LocalTemperature via a script:
log(res, err)
  log(temperature)
Hi admin,
i'm testing the code, this is the log on the zigbee device
Manufacturer: Rti-Tek
Model: Thermostat
Firmware version: 2.2
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- HvacThermostat (513)
- HaDiagnostic (2821)
- 64527
Output clusters
- Time (10)
- Ota (25)
Reported attributes
- heatingstatus: true
- localtemperature: 26.20
- occupiedheatingsetpoint: 27.00
- systemmode: 1
I have filled my script in this way;
--log(zb)
addr = '84fd27fffea5ec1c'
attrs = { 'heatingstatus' }
log(res, err)
if type(res) == 'table' and res.heatingstatus then
  --temperature = res.LocalTemperature / 100
  log(res.heatingstatus)
In log I have this error:
* arg: 1
  * nil
* arg: 2
  * string: .../tmp.VsS0GSqtJq/files/store/daemon/zigbee/zigbee/zcl.lua:167: attempt to index a nil value
Where am I wronging?
You need to read the SystemMode attribute. If it's not zero then the heating is enabled. You can read multiple attributes from the same cluster by adding multiple names to the attrs table.
In the next app version read response will be treated the same as reporting that devices send from time to time. This means that mapped objects will be updated automatically. It will be enough to send the attribute read request without adding any extra code for parsing values.
(15.09.2023, 05:14)admin Wrote: You need to read the SystemMode attribute. If it's not zero then the heating is enabled. You can read multiple attributes from the same cluster by adding multiple names to the attrs table.
Is there any way to know attributes names?
Here's a list of clusters and respective attributes.
Basic (0x0000)
  ZCLVersion
  HwVersion
  ManufacturerName
  ModelId
  SwBuildId
PowerCfg (0x0001)
  BatteryVoltage
  BatteryLevel
OnOff (0x0006)
  OnOff
LevelCtrl (0x0008)
  CurrentLevel
  OnOffTransitionTime
  OnLevel
  StartUpCurrentLevel
LightingColorCtrl (0x0300)
  CurrentHue
  CurrentSaturation
  RemainingTime
  CurrentX
  CurrentY
  ColorTemperature
  ColorMode
  EnhancedCurrentHue
  EnhancedColorMode
  ColorCapabilities
  ColorTempPhysicalMin
  ColorTempPhysicalMax
LightingBallastCfg (0x0301)
  PhysicalMinLevel
  PhysicalMaxLevel
  MinLevel
  MaxLevel
  ControlMode
MsIlluminanceMeasurement (0x0400)
  MeasuredValue
MsTemperatureMeasurement (0x0402)
  MeasuredValue
  TemperatureSensorType
MsPressureMeasurement (0x0403)
  MeasuredValue
MsRelativeHumidity (0x0405)
  MeasuredValue
AnalogInput (0x000C)
  Description
  MaxPresentValue
  MinPresentValue
  OutOfService
  PresentValue
  Reliability
  RelinquishDefault
  Resolution
BinaryInput (0x000F)
  PresentValue
HvacThermostat (0x0201)
  LocalTemperature
  OutdoorTemperature
  Occupancy
  AbsMinHeatSetpointLimit
  AbsMaxHeatSetpointLimit
  AbsMinCoolSetpointLimit
  AbsMaxCoolSetpointLimit
  PICoolingDemand
  PIHeatingDemand
  HVACSystemTypeConfiguration
  LocalTemperatureCalibration
  OccupiedCoolingSetpoint
  OccupiedHeatingSetpoint
  UnoccupiedCoolingSetpoint
  UnoccupiedHeatingSetpoint
  MinSetpointDeadBand
  RemoteSensing
  ControlSequenceOfOperation
  SystemMode
  AlarmMask
  ThermostatRunningMode
HvacFanCtrl (0x0202)
  FanMode
  FanModeSequence
HaElectricalMeasurement (0x0B04)
  RmsVoltage
  RmsCurrent
  HaActivePower
  HaReactivePower
  HaApparentPower
  PowerFactor
  VoltageMultiplier
  VoltageDivisor
  CurrentMultiplier
  CurrentDivisor
  HaPowerMultiplier
  HaPowerDivisor
SeMetering (0x0702)
  CurrentSummDelivered
  SePowerMultiplier
  SePowerDivisor
  SeActivePower
SsIasZone (0x0500)
  ZoneState
  ZoneType
  ZoneStatus
  IasCieAddr
  ZoneId
  ZoneSensitivityLevel
  DetectionTimeout
ClosuresDoorLock (0x0101)
  LockState
  LockType
  ActuatorEnabled
  DoorState
ClosuresWindowCovering (0x0102)
  WindowCoveringType
  PhysicalClosedLimitLift
  PhysicalClosedLimitTilt
  CurrentPositionLift
  CurrentPositionTilt
  NumberOfActuationsLift
  NumberOfActuationsTilt
  ConfigStatus
  CurrentPositionLiftPercentage
  CurrentPositionTiltPercentage
  Mode
  LiftDriveUpTime
  LiftDriveDownTime
  TiltOpenCloseAndStepTime
  TiltPositionPercentageAfterMoveToLevel
MsOccupancySensing (0x0406)
  Occupancy
  OccupancySensorType
  PirOToUDelay
  OccupancyDfltOperationMode
(15.09.2023, 13:40)admin Wrote: Here's a list of clusters and respective attributes.
Basic (0x0000)
  ZCLVersion
  HwVersion
  ManufacturerName
  ModelId
  SwBuildId
PowerCfg (0x0001)
  BatteryVoltage
  BatteryLevel
OnOff (0x0006)
  OnOff
LevelCtrl (0x0008)
  CurrentLevel
  OnOffTransitionTime
  OnLevel
  StartUpCurrentLevel
  CurrentHue
  CurrentSaturation
  RemainingTime
  CurrentX
  CurrentY
  ColorTemperature
  ColorMode
  EnhancedCurrentHue
  EnhancedColorMode
  ColorCapabilities
  PhysicalMinLevel
  PhysicalMaxLevel
  MinLevel
  MaxLevel
  ControlMode
  MeasuredValue
  MeasuredValue
  MeasuredValue
  MeasuredValue
  Description
  MaxPresentValue
  MinPresentValue
  OutOfService
  PresentValue
  Reliability
  RelinquishDefault
  Resolution
  PresentValue
  LocalTemperature
  OutdoorTemperature
  Occupancy
  PICoolingDemand
  PIHeatingDemand
  MinSetpointDeadBand
  RemoteSensing
  SystemMode
  AlarmMask
  FanMode
  FanModeSequence
  RmsVoltage
  RmsCurrent
  HaActivePower
  HaReactivePower
  HaApparentPower
  PowerFactor
  VoltageMultiplier
  VoltageDivisor
  CurrentMultiplier
  CurrentDivisor
  HaPowerMultiplier
  HaPowerDivisor
SeMetering (0x0702)
  SePowerMultiplier
  SePowerDivisor
  SeActivePower
SsIasZone (0x0500)
  ZoneState
  ZoneType
  ZoneStatus
  IasCieAddr
  ZoneId
  DetectionTimeout
  LockState
  LockType
  ActuatorEnabled
  DoorState
  WindowCoveringType
  CurrentPositionLift
  CurrentPositionTilt
  ConfigStatus
  Mode
  LiftDriveUpTime
  LiftDriveDownTime
  Occupancy
  OccupancySensorType
  PirOToUDelay
Hello Team:
Where can I find this list of clusters and respective attributes, updated?
May be somethink like:
https://kb.logicmachine.net/libraries/zigbee/
best regard
Roger
Roger
This list is mostly up to date. The only major difference in the current version is addition of Phase B/C attributes to HaElectricalMeasurement.
Which clusters/attributes do you need?
