09.10.2024, 13:44
Hi.
I need help with a script for a lighting case, i have a spacelynk and Daligw, normal puschbutton to a binary input.
the costumer want to have 2 puschbuttons, 1st to start the light at 80% and after 60 min it will go down to 30 % in 10min and then 0%
the other button start at 80% for 240 min and then 30% in 10min and 0%.
It should be possible to turn off the light manually when the countdown has started, the binary input has 2 outgoing object for each channel (schneider).
Maybe stop/off with long press.
I have tried a Timer made here that`s seams to work, but if i send 0% to the gateway the script is still running and lights up when the lower value start.
The script i tested was this:
if not client then
timers = {
['12/1/10'] = {
output = '12/1/12', -- dimmer control (0..100%)
onvaluehigh = 80, -- high output value in %
onvaluelow = 30, -- low output value in %
timeouthigh = 1 * 15, -- time to keep high value (in seconds)
timeoutlow = 1 * 10, -- time to keep low value (in seconds)
function timersetstate(timer, state)
grp.checkwrite(timer.output, timer['onvalue' .. state] or 0)
timer.state = state
timer.ticks = timer['timeout' .. state]
function timertimeout(timer)
local state = timer.state == 'high' and 'low' or 'off'
for _, timer in ipairs(timers) do
timer.state = 'off'
grp.sender = 'tm'
client = require('localbus').new(0.1)
client:sethandler('groupwrite', function(event)
local timer = timers[ event.dst ]
if timer and event.sender ~= grp.sender then
local value = tonumber(event.datahex, 16) or 0
if value == 1 then
timersetstate(timer, 'high')
end)
client:loop(1)
for _, timer in pairs(timers) do
if timer.ticks then
timer.ticks = timer.ticks - 1
if timer.ticks == 0 then
timertimeout(timer)
