SONOS app
Do you use Mosaic? If no just create a floor and a room in it, also make sure it is a latest version.
(11.09.2019, 07:47)Daniel Wrote: Hi
Here is how to use new Sonos app via script:
The app runs a daemon which keeps communication with each player/group The daemon will be closed down after 120s if no update is send so we need to run such script every 60s to keep communication up and running.
require('custom.sonos.lib') groupID=sonos_app.GetStoragePlayerGroups() for k, v in pairs(groupID) do    sonos_app.SendApiActionCommand(k, 'watchPlayerGroup', os.time()) end
To control the players we need to know groupID which can be read via such command.
Basic control is done like this
-- simle command: play, pause, skipToPrev, skipToNext sonos_app.SendApiActionCommand(url_group_id, 'play')
-- set volume sonos_app.SendApiActionCommand(url_group_id, 'setVolume', 50)
The url_group_id is in the table from the groupID but it can be read automatically when we know group name so example start/pause script would looks like that.
1234567891011121314151617181920
require('custom.sonos.lib') groupName='Kitchen' ------------------------------------------------------------- groupID=sonos_app.GetStoragePlayerGroups() for k, v in pairs(sonos_app.GetStoragePlayerGroups()) do   if groupID[k].groupName == groupName then   groupID=k      break   end end ------------------------------------------------------------- value = event.getvalue() if value then     sonos_app.SendApiActionCommand(groupID, 'play') else   sonos_app.SendApiActionCommand(groupID, 'pause') end
To read Playlist table use this
sonos_app.GetStoragePlayerGroupData(groupID, 'Playlists')
To Play a playlist
-- play playlist by ID sonos_app.SendApiActionCommand(url_group_id, 'playPlaylist', playlist_id)
playlist_id looks like a number but it is a string!
To read Favorites use
sonos_app.GetStoragePlayerGroupData(groupID, 'Favorites')
To play a Favorites
sonos_app.SendApiActionCommand(url_groupID, 'playFavorite', url_favID)
Are there more functions then what is listed here? Specifically I would like to group and ungroup players via script.
In the app is there a way of changing the banner an icon colours from green to another colour, also is it possible to remove the close button?
