SONOS app
Do you use Mosaic? If no just create a floor and a room in it, also make sure it is a latest version.
(11.09.2019, 07:47)Daniel Wrote: Hi
Here is how to use new Sonos app via script:
The app runs a daemon which keeps communication with each player/group The daemon will be closed down after 120s if no update is send so we need to run such script every 60s to keep communication up and running.
require('custom.sonos.lib') groupID=sonos_app.GetStoragePlayerGroups() for k, v in pairs(groupID) do    sonos_app.SendApiActionCommand(k, 'watchPlayerGroup', os.time()) end
To control the players we need to know groupID which can be read via such command.
Basic control is done like this
-- simle command: play, pause, skipToPrev, skipToNext sonos_app.SendApiActionCommand(url_group_id, 'play')
-- set volume sonos_app.SendApiActionCommand(url_group_id, 'setVolume', 50)
The url_group_id is in the table from the groupID but it can be read automatically when we know group name so example start/pause script would looks like that.
require('custom.sonos.lib') groupName='Kitchen' ------------------------------------------------------------- groupID=sonos_app.GetStoragePlayerGroups() for k, v in pairs(sonos_app.GetStoragePlayerGroups()) do   if groupID[k].groupName == groupName then   groupID=k      break   end end ------------------------------------------------------------- value = event.getvalue() if value then     sonos_app.SendApiActionCommand(groupID, 'play') else   sonos_app.SendApiActionCommand(groupID, 'pause') end
To read Playlist table use this
sonos_app.GetStoragePlayerGroupData(groupID, 'Playlists')
To Play a playlist
-- play playlist by ID sonos_app.SendApiActionCommand(url_group_id, 'playPlaylist', playlist_id)
playlist_id looks like a number but it is a string!
To read Favorites use
sonos_app.GetStoragePlayerGroupData(groupID, 'Favorites')
To play a Favorites
sonos_app.SendApiActionCommand(url_groupID, 'playFavorite', url_favID)
Are there more functions then what is listed here? Specifically I would like to group and ungroup players via script.
In the app is there a way of changing the banner an icon colours from green to another colour, also is it possible to remove the close button?
is there a way to add the play favorite button ?
https://forum.logicmachine.net/showthrea...9#pid13969
last example
(07.01.2026, 16:17)Daniel Wrote: https://forum.logicmachine.net/showthrea...9#pid13969
last example
i already tried this   sonos_app.GetStoragePlayerGroupData(groupID, 'Favorites')
and i get this to erro logs Us
Did you try the play/pause script?
(07.01.2026, 16:47)Daniel Wrote: Did you try the play/pause script?
Yes also doesnt work
But it works from the wighet
Did you fallow the instructions and created first script in this post?
(08.01.2026, 08:27)Daniel Wrote: Did you fallow the instructions and created first script in this post?
Yes i have made a resident script every 60 sec
If you have this script working then first try basic play/pause
Create a bit object and then event script on it.  use this script and change Bedroom to your group name, you can see it in Sonos app on the bottom.
require('custom.sonos.lib') groupName='Bedroom' ------------------------------------------------------------- groupID=sonos_app.GetStoragePlayerGroups() for k, v in pairs(sonos_app.GetStoragePlayerGroups()) do   if groupID[k].groupName == groupName then   groupID=k     break   end end ------------------------------------------------------------- value = event.getvalue() if value then     sonos_app.SendApiActionCommand(groupID, 'play') else   sonos_app.SendApiActionCommand(groupID, 'pause') end
https://app.screencast.com/zJSLrszerduNH
Thank You The problem was that I had a _ in the name!
Is there any way to play a specific album?
if you add it to favorite then you can play a specific favorite from there.
(12.01.2026, 08:39)Daniel Wrote: if you add it to favorite then you can play a specific favorite from there.
Hello again when i try to read the the play favorites i get this (Image)
Im trying with this script but i cant make it work
require('custom.sonos.lib') groupName='Living Room' ------------------------------------------------------------- groupID=sonos_app.GetStoragePlayerGroups() for k, v in pairs(sonos_app.GetStoragePlayerGroups()) do   if groupID[k].groupName == groupName then   groupID=k      break   end end ------------------------------------------------------------- value = event.getvalue() if value then -- play playlist by ID sonos_app.SendApiActionCommand(url_group_id, 'playPlaylist', 491) end
You probably need to change
groupID=k
    break
into
url_group_id = k
    break
