02.10.2024, 14:02
		Does the Wireshark info give any clue?
					LM Home app (Andrоid/iOS starter)
		02.10.2024, 14:02
		02.10.2024, 15:08
		Never mind, I fixed it   I logged in to my LM via cloud and then re-enabled my wifi on my phone and then it discovered it instantly!
		02.10.2024, 17:25
		05.10.2024, 04:01
		Currently I have applied this push notification function via LMhome app on iphone(ios), but I can only receive push notifications when I connect my phone to internal wifi in the house, using wifi or other network outside the house is not possible. With android it is perfect Please support Thank you
		05.10.2024, 08:50
		Just tried on iPhone with latest iOS and works fine on wifi and on 4G. We do not have any control over it from the cloud to mobile, it is just standard push notification service. Where are you based?
------------------------------ Ctrl+F5
		05.10.2024, 09:31
	 (05.10.2024, 08:50)Daniel Wrote: Just tried on iPhone with latest iOS and works fine on wifi and on 4G. We do not have any control over it from the cloud to mobile, it is just standard push notification service. Where are you based? I'm in Vietnam, do you mean this feature already works on IOS (receive push notifications when using network outside home)?
		07.10.2024, 11:28
(This post was last modified: 07.10.2024, 12:01 by gjniewenhuijse.)
	 (23.02.2024, 23:58)icuzz Wrote:(23.02.2024, 07:11)phongvucba Wrote:(23.02.2024, 06:18)alexll Wrote: What can we do if we are in an enterprise network enviroment and the WiFi network is in a different subnet? I can access into my LM locally typing its IP in my webbrowser, but LM Home says "No LogicMachine devices found"hi everyone ! +1 Is this on the schedule? very important for my customers to add them remote. Best way is that i can send an mail to the customer and then he have access to his lm with the right user.
		07.10.2024, 13:48
(This post was last modified: 07.10.2024, 15:21 by gjniewenhuijse.)
		Sometimes you end up in the LM Home app in a completely white screen. Then you can't do anything at all. Closing the app and restarting it doesn't help either, because then you end up back in the white empty screen. Shouldn't there always be a button somewhere that you can use to go to your home? Or a back button? For now i have to clear config. And go back to the location of my LM to add them to the app. And i can create a user with name gert-jan, but opening the settings gives an error: username already exists or invalid
		23.10.2024, 09:55
		Hi  In one of project , LM Home can't find the local LM5. LM5 is latest 2024 FW. We can open LM home page from phone browser but we can't find via LM Home. For network, they are in the same network, same ip block but it just don't work. As i understood from the topics above, new automatic find system is based on something called mdns. What should we talk with network guys for this mdns ? What they have to do ? Should they open some ports ?
		24.10.2024, 09:58
		I have successfully applied this function to both Android and iOS, but Android makes a notification sound but iOS doesn't. Can you guide me, admin? Thank you.
		24.10.2024, 09:59
		What do you mean by 'notification sound'? push notification?
		24.10.2024, 16:06
		24.10.2024, 21:00
		Push notifications have nothing to do with the app, you must check system settings.
		12.11.2024, 06:56
		Can we have a pop-up function showing is being activated when executed? Like the China app where they will show “executed”. It's difficult to tell if it is executed presently.
		12.11.2024, 09:06
	 (12.11.2024, 06:56)Deltec Wrote: Can we have a pop-up function showing is being activated when executed? Like the China app where they will show “executed”. It's difficult to tell if it is executed presently. Can you explain in more details what do you have in mind? The above is not clear to us.
		12.11.2024, 09:12
		New version of LM Home app is available on Play Store and App Store.  - Added option to add LogicMachine manually. - Added option to go to LM Cloud directly. - All configurable options are grouped together under Settings button. - If no local LM is found then app will allow to use LM Cloud access.
		12.11.2024, 09:19
	 (12.11.2024, 06:56)Deltec Wrote: Can we have a pop-up function showing is being activated when executed? Like the China app where they will show “executed”. It's difficult to tell if it is executed presently. One of our client was asking for example; if we click on an action " Close the gate". Can there be a pop up "Gate closed". They want a pop-up showing that the action has been executed.
		12.11.2024, 09:21
		Don't you have a feedback on your drive to tell you this?  Which visualization do you use?
------------------------------ Ctrl+F5 |
