Negative Number
Hi Guys,
I’m working on a script to get the electricity prices from an API and write those prices to a group address. So far, everything works fine except when the value is negative. For example, -0.00036. In this case, the 2-byte object gets 0 as a value. How can I solve this?
Thanks in advance.
local http = require('ssl.https') local json = require('json') local date = os.date('*t') -- get today's date local year = tostring(date.year) local month = string.format('%02d', date.month) local day = string.format('%02d', date.day) local area = 'NO3' -- specify area local url = string.format('https://www.hvakosterstrommen.no/api/v1/prices/%s/%s-%s_%s.json', year, month, day, area) log('Fetching data from URL:', url) local body, code, headers, status = http.request(url) log('HTTP response code:', code) if code == 200 then     --log('Data retrieved successfully')     --log('Response body:', body)     local data = json.decode(body)     log(data)     local min_price = math.huge -- start with a very high value for minimum     local max_price = -math.huge -- start with a very low value for maximum     local total_price = 0     local count = 0     for i, item in ipairs(data) do         local start_hour = string.sub(item.time_start, 12, 13)         local end_hour = string.sub(item.time_end, 12, 13)         local price = item.NOK_per_kWh         -- Calculate min, max, and total prices for average         if price < min_price then min_price = price end         if price > max_price then max_price = price end         total_price = total_price + price         count = count + 1         local time_range = string.format("%s TIL %s", start_hour, end_hour)       --  log("Time Range:", time_range)       --  log("Price:", price)                             local address = '35/0/' .. i  -- Example: '35/0/1', '35/0/2', etc.             grp.create({name = time_range, address = address, datatype = 09})             grp.write(time_range, price )                         -- Small delay between each write             os.sleep(0.)                     end     local average_price = total_price / count     grp.write('35/1/0', min_price )     grp.write('35/1/1', max_price )     grp.write('35/1/2', average_price) else     log('Error fetching data:', status) end
Use DPT 14 (4 byte floating point). Disable grp.create call when the objects are already created.
(05.11.2024, 07:51)admin Wrote: Use DPT 14 (4 byte floating point). Disable grp.create call when the objects are already created.
Thanks , why I can't read a negative value with four decimal places in Mosaic ? am I doing something wrong ? Mosaic is showing 0 while the value is -0.00036
As a work-around you can use string/text data type and format the value in the script:
value = string.format('%.4f', value) -- 4 decimal places
(05.11.2024, 08:15)admin Wrote: As a work-around you can use string/text data type and format the value in the script:
Thaanks
