Mosaic and Virtual Object
hello
Does Mosaic have limitations in using virtual addresses? I had a client say that I only see the first 100 of the 32/1/* group
No, each widget has filter for dpts which are related to it. Most likely it is this.
(14.11.2024, 12:38)Daniel Wrote: No, each widget has filter for dpts which are related to it. Most likely it is this.
Hi I try to use 2 widdget one for see one temp value virtual address, and one for change set of temperature  also virtual addre , setpoint is possible to connect view value not.
DPT one 9.2 byte float floyting and other 14 4 byte float, now I need convert in the same dpt correct ?
in this case yes
