scripitng
hello i made this script i receive to error logs this ( User script:13: attempt to call field 'listen' (a nil value) stack tracebackSmilean anyone help me
local smtp_server = 'logicmachine email'
local smtp_port = 587
local smtp_user = 'admin'
local smtp_pass = 'admin'
local recipient = 'mariospoulorinis@gmail.com'
local subject = 'Ειδοποίηση: Ενεργοποίηση αισθητήρα βροχής'
local message = 'Ομπρέλα να πάρεις'
event.listen(rain_sensor_ga, function(event)
  if value == true then
    log
  ' email(smtp_server, smtp_port, smtp_user, smtp_pass, recipient, subject, message)'
end)
Please stop using chatGPT and search for examples on the forum.
i tried this from the forum and it didnt work
value = event.getvalue()
to = 'test@test.com'
subject = 'Alert'
message = 'KNX object 1/2/2 value is: ' .. tostring(value)
res, err = mail(to, subject, message)
if not res then
  log(err)
Did you setup, common functions with your email server settings?
yes and i get this * string: 535-5.7.8 Username and Password not accepted. For more information, go to
535 5.7.8 https://support.google.com/mail/?p=BadCredentials 5b1f17b1804b1-433b01e1030sm85985385e9.7 - gsmtp
but i cheked the username and the password
See this
https://forum.logicmachine.net/showthrea...1#pid26361
now i get this
* string: host not found
Check smpt server, seems it is wrong.
(22.11.2024, 12:23)Daniel Wrote: Check smpt server, seems it is wrong.
i fixed that now i get this * string: Address not available
Send you backup via PM.
