Timer - How to improve
Hi everyone,
I'm using a script found on this forum, by Daniel, I believe, which I've modified a little to suit my needs. The only problem I'm having is that every time a READ passes on the bus, the updatetime value is updated, so my timer doesn't work as expected. Do you have any ideas? Thanks in advance
timers = {
    name = 'TEST',
    input = '0/6/100',
    inputValueForTrigger = false,
    output = '14/0/202',
    outputValue = true,
    outputTimeMinutes = 6,
    writeInverseValue = true
for _, timer in ipairs(timers) do
  -- find required object
  obj = grp.find(timer.input)
  -- object exists and current state is "on"
  if obj and obj.data == timer.inputValueForTrigger then
    -- delta is in seconds
    delta = os.time() - obj.updatetime
    -- switch when timer expires
    if delta >= timer.outputTimeMinutes * 60 then
      grp.checkwrite(timer.output, timer.outputValue)
    if obj then
      if timer.writeInverseValue then
        grp.checkwrite(timer.output, not timer.outputValue)
Map an event script to the input object and save the current timestamp in storage:
key = 'updatetime_' .. event.dst
time = os.time()
storage.set(key, time)
Then modify your timer script:
key = 'updatetime_' .. timer.input
time = storage.get(key, 0)
delta = os.time() - time
Thanks you,
this is the solution I wanted to avoid, I find it very comfortable to have all the timers in one file.
I don't yet know how “localbus” works, but couldn't I manage to create a kind of write capture?
Is there a place where I can find documentation?
You can modify one of these scripts to suit your needs:
https://kb.logicmachine.net/scripting/staircase-timer/
https://forum.logicmachine.net/showthrea...0#pid36530
https://forum.logicmachine.net/showthrea...7#pid36717
Thanks you, I was able to do what I wanted
