30.12.2024, 22:31
Hello, has anyone any experience with LSS100100 and dahua panel VTH5341. If I connect from panel to LSS100100 via Google with IP adress I can´t see the Touch and Touch config icons. Can anyone help me? Thank you.
30.12.2024, 22:31
02.01.2025, 11:48
Check that you have enabled access to Touch in User access settings.
02.01.2025, 20:40
(This post was last modified: 02.01.2025, 20:51 by Petervarga.)
(02.01.2025, 11:48)admin Wrote: Check that you have enabled access to Touch in User access settings. Ijghj (02.01.2025, 20:40)Petervarga Wrote:(02.01.2025, 11:48)admin Wrote: Check that you have enabled access to Touch in User access settings. I tried to connect via google from my mobile and it worked, but i can not do it only from this panel. It worked before, but when I change sw on 3.0 in LSS100100 it not work.
03.01.2025, 05:52
Try clearing browser cache on the panel..
03.01.2025, 07:24
Try uninstalling all other apps but Touch. You should not use admin user for visualization. Create a separate user and set access rights accordingly.
