Modbus profiles write_delay
Hi, I've seen that recently you have added a "write_delay" field.
Is it possible to use this modbus package on 20230607 firmware?
This feature has not been tested yet. But you can try at your own risk if you want.
https://dl.openrb.com/pkg/genohm-scada-m...7_imx6.ipk
https://dl.openrb.com/pkg/genohm-scada-m...7_imx6.sig
Install through System config > System > Packages > Add package. Reboot LM after installation.
(20.06.2024, 11:28)admin Wrote: This feature has not been tested yet. But you can try at your own risk if you want.
Hi I've tried but it seems that write doesn't work...
Anything in the Modbus logs or Error logs?
(21.06.2024, 13:53)admin Wrote: Anything in the Modbus logs or Error logs?
/lib/genohm-scada/plugins/modbus/daemon.lua:0: attempt to index a nil value
We'll take a look and publish an update next week.
(21.06.2024, 13:58)admin Wrote: We'll take a look and publish an update next week.
Ok thanks!
Use this package, write_ delay works here
https://dl.openrb.com/pkg/genohm-scada-m...1_imx6.ipk
https://dl.openrb.com/pkg/genohm-scada-m...1_imx6.sig
(24.06.2024, 09:53)Daniel Wrote: Use this package, write_ delay works here
Hi I've tested and it works!
How are writes managed? I've seen that dependig on the value set in poll time, only one write is done at the end of each poll...
Writes can only happen between poll cycles. Polling cycle for a single device cannot be interrupted by a write operation.
You should adjust the poll interval so the bus is not completely occupied by reading.
(25.06.2024, 09:01)admin Wrote: Writes can only happen between poll cycles. Polling cycle for a single device cannot be interrupted by a write operation.
Ok understood. Thanks!
Hi Daniel,
Are this packages in the latest firmware?
We have done some tests and it seems that write_delay doesn't work unless we import them...
What is latest firmware for you?
(08.01.2025, 09:20)Daniel Wrote: What is latest firmware for you?
20240426
Then NO, it is not there.
(08.01.2025, 09:24)Daniel Wrote: Then NO, it is not there.
Is it the latest one?
Official one yes, I use  20241121 Wink
(08.01.2025, 09:27)Daniel Wrote: Official one yes, I use  20241121 Wink
OK!!
