Create User with DB
Hi all,
I add a user to the database like this :
    local user = {
        name = db:escape(name),
        login = db:escape(login),
        password = hashpassword(db:escape(login), "123456"),
        homepage = "apps-fcs",
        access_apps = "P",
        access_vis = '',
        access_mosaic = "F",
        access_schedulers = '',
        access_trends = '',
        allow_objects = "",
        active = 1
    result, err = db:insert('users', user)
    io.readproc('/etc/init.d/nginx reload')
The user is added, but when I'm try to connect, I get a 403 error !
any idea ?
thanks
Use webrequest library: https://forum.logicmachine.net/showthread.php?tid=4425
You don't need to escape/has any values.
Hi admin,
I forgot to mention that I was in a .lp file for an app.
Where did the 403 error come from? j
In current firmware you should be able to use webrequest in .lp files.
You have partial apps access set but no ACL for apps provided.
