Password Script and touch
I'm trying to make a script that allows users of the LogicMachine to change their password. The problem is that it deactivates the touch associated with each user and I need each one to see their screen.
Any clues?
Thank you in advance
require('apps') require('json') require('socket.http') require('socket.url') continua = true i = 1 users = db:getall('SELECT id, login FROM users') nombre = event.getvalue() while users[i] ~= nil and continua == true do     name = users[i].login   if name == nombre then     ide = users[i].id     j=i     continua = false   end   i = i+1 end         acl = {         vis ={}, -- Table with the pages to which the user has access         schedulers = {},         trends = {}         } log (users[j]) log (ide,j,nombre) log('log',users[j]) pass= 'Passw123' data = {   id = ide,   name = nombre, -- full name   login = nombre, -- login   password = pass, -- password   password_repeat = pass, -- must match password   active = true,   --access_vis = 'P', -- partial access to visualization   --access_schedulers = '', -- no access to schedulers -- access_trends = 'P', --F', -- full access to trends     acces_apps ='P',      acces_touch ='F',              allow_objects = "",   homepage = "apps-touch", acl = json.encode(acl) } post = 'data=' .. socket.url.escape(json.encode(data)) res, err = socket.http.request('http://admin:Password1@127.0.0.1/scada-main/users/save', post) log(res, err, pass)
Use webrequest library: https://forum.logicmachine.net/showthread.php?tid=4425
Some of the configuration fields are spelled incorrectly (acces_apps/acces_touch) and you set partial access without ACL.
Use browser dev tools (F12) to check which fields/values are sent from the admin UI.
Hi again,
I have fixed the errors that you had told me and applied the changes and it has worked perfectly.
Thank you so much  Smile
