Read from the logic machine
Hello, so far I'm starting to work with logic machine, I've been connecting the logic machine to a pc through the rs232 port, I've succeeded and I could write from the logic machine to a pc terminal, but I do not know how to read To the pc from the logic Is this possible?
Sorry for the translation, I do not speak English.
Thank you.
Here's the documentation on serial library:
http://openrb.com/docs/serial.htm
Here's a small example that will send back everything that LM reads from RS232 (default serial settings are 115200 8N1):
-- open port on first call if not port then   require('serial')   port = serial.open('/dev/RS232')   port:flush() end -- port ready if port then   -- read one byte   char = port:read(1, 1)   -- send back if read succeeded   if char then     port:write(char)   end end
Excuse at what point could you see the reading results? Since the logs?
Thanks for your help.
It will send it back to your PC, if you want to log it, you can add log(char) after port:read(1, 1)
Thank you, you have been very helpful.
