Homewizard Energy API P1 Telegram
I bought a Homewizard Wi-fi P1 meter for reading out my electric meter.
This device has an API that returns it's data in plain text (not json).
For example:
<Request>
GET http://{IP address}/api/v1/telegram
<Response>
HTTP/1.1 200 OK
Content-Type: text/plain
Content-Length: <length>
/ISK5\\\\2M550T-10111-
3:0.2.8(50)
0-0:1.0.0(181106140429W)
0-0:96.1.1(31333631353032362020202020202020)
1-0:1.8.1(10830.511*kWh)
1-0:1.8.2(002948.827*kWh)
I was wondering if there is any post on the forum someone knows of which should be a good start for a script to read out the data.
Thanks in advance,
Tig
Try this. This example assumes that strings like "1-0:1.8.2" are unique value keys that are unchanged between requests.
url = 'http://{IP address}/api/v1/telegram'
response = require('socket.http').request(url)
lines = response:split('\n')
result = {}
for _, line in ipairs(lines) do
  line = line:trim()
  pos = line:find('(', 1, true)
  if pos then
    key = line:sub(1, pos - 1)
    val = line:sub(pos + 1, -2)
    val = val:gsub('[^%d%.]+', '')
    result[ key ] = tonumber(val)
log(result)
grp.checkupdate('1/1/1', result['1-0:1.8.1'])
grp.checkupdate('1/1/2', result['1-0:1.8.2'])
--P1 poort van slimme meter via HomeWizard uitlezen
ip = '192.168.1.192' --Vul hier het IP adres van de HomeWizard P1 meter in
socket.http.TIMEOUT = 5
data = socket.http.request('http://'..ip..'/api/v1/telegram')
if data then
  --log(data)
  -- Totaal verbruik tarief 1 uitlezen kWh
  tarief_1 = data:match'1-0:1.8.1%((%d+.%d+)'
  tarief_1 = tonumber(tarief_1)
    --log("Tarief 1: " .. tarief_1 .. " kWh")
  grp.update('8/0/1', tarief_1)
  -- Totaal verbruik tarief 2 uitlezen kWh
  tarief_2 = data:match'1-0:1.8.2%((%d+.%d+)'
  tarief_2 = tonumber(tarief_2)
  --log("Tarief 2: " .. tarief_2 .. " kWh")
  grp.update('8/0/2', tarief_2)
  -- Totaal verbruik tarief 1 + 2
  tarief_totaal = tarief_1 + tarief_2
  --log("Totaal verbruik: " .. tarief_totaal .. " kWh")
  grp.update('8/0/0', tarief_totaal)
  -- Totaal verbruik €
  verbruik_prijs_kWh = grp.getvalue('8/0/11')
  totaal_verbruik_€ = tarief_totaal * verbruik_prijs_kWh
  --log("Totaal verbruik: €" .. totaal_verbruik_€)
  grp.update('8/0/13', totaal_verbruik_€)
  -- Totale retourlevering tarief 1 uitlezen kWh
  retour_1 = data:match'1-0:2.8.1%((%d+.%d+)'
  retour_1 = tonumber(retour_1)
  --log("Retour 1: " .. retour_1 .. " kWh")
  grp.update('8/0/4', retour_1)
  -- Totale retourlevering tarief 2 uitlezen kWh
  retour_2 = data:match'1-0:2.8.2%((%d+.%d+)'
  retour_2 = tonumber(retour_2)
  --log("Retour 2: " .. retour_2 .. " kWh")
  grp.update('8/0/5', retour_2)
  -- Totale retourlevering tarief 1 + 2
  retour_totaal = retour_1 + retour_2
  --log("Totaal retour: " .. retour_totaal .. " kWh")
  grp.update('8/0/3', retour_totaal)
  -- Totaal retourlevering €
  retour_prijs_kWh = grp.getvalue('8/0/12')
  totaal_retour_€ = retour_totaal * retour_prijs_kWh
  --log("Totaal retour: €" .. totaal_retour_€)
  grp.update('8/0/14', totaal_retour_€)
  -- Actuele tariefstand uitlezen T1/T2
  actueel_tarief = data:match'14.0%((%d+)'
  actueel_tarief = tonumber(actueel_tarief)
  --log("Actueel tarief: T" .. actueel_tarief)
  grp.update('8/0/10', actueel_tarief)
  -- Actueel verbruik uitlezen kW
  actueel_verbruik = data:match'1-0:1.7.0%((%d+.%d+)'
  actueel_verbruik = tonumber(actueel_verbruik)
  --log("Actueel verbruik: " .. actueel_verbruik .. " kW")
  grp.update('8/0/6', actueel_verbruik)
  -- Actueel verbruik W
  actueel_verbruik_W = actueel_verbruik*1000
  --log("Actueel verbruik: " .. actueel_verbruik_W .. " W")
  grp.update('8/0/7', actueel_verbruik_W)
  -- Actueel verbruik €
    actueel_verbruik_€ = actueel_verbruik * verbruik_prijs_kWh
    --log("Actueel verbruik: €" .. actueel_verbruik_€)
  grp.update('8/0/15', actueel_verbruik_€)
  -- Actuele retourlevering uitlezen kW
  actueel_retour = data:match'1-0:2.7.0%((%d+.%d+)'
  actueel_retour = tonumber(actueel_retour)
  --log("Actueel retour: " .. actueel_retour .. " kW")
  grp.update('8/0/8', actueel_retour)
  -- Actuele retourlevering W
  actueel_retour_W = actueel_retour *1000
  --log("Actueel retour: " .. actueel_retour_W .. " W")
  grp.update('8/0/9', actueel_retour_W)
  -- Totale gasverbruik uitlezen m³
gas = data:match'.+%((%d+.%d+)'
gas = tonumber(gas)
--log("Gas: " .. gas .. " m³")
  grp.update('8/1/0',gas)
  -- Totaal gasverbruik €
  verbruik_prijs_M³ = grp.getvalue('8/1/1')
  totaal_gasverbruik = gas * verbruik_prijs_M³
  --log("Totaal gasverbruik: €" .. totaal_gasverbruik_€)
  grp.update('8/1/2', totaal_gasverbruik)
Omg, you are amazing! Thank you very much I'll try it out asap!
Kudos to Admin & Danny!
Hello
how to read the peak from 1-0:1.6.0(230514091500S)(01.672*kW)
i try it like this but i don't get a good value:
  -- Afnamepiek van dit maand  1-0:1.6.0(230514091500S)(01.672*kW)
  afnamepiek = data:match([[1-0:1.6.0%(()(%d+)]])
  if nil ~= afnamepiek then
    afnamepiek = tonumber(afnamepiek)
    --log("Afnamepiek: " .. afnamepiek .. " kW")
    grp.checkupdate('32/0/13', afnamepiek)
if data then
  --log(data)
gas = tonumber(gas)
Thank you this works perfect but i want to read this also :
 "Afnamepiek van dit maand"   in this format : 1-0:1.6.0(230514091500S)(01.672*kW)
if data then
  --log(data)
gas = tonumber(gas)
Just add this:
--Afnamepiek
  afnamepiek = data:match'1-0:1.6.0%((%d+.%d+)'
  grp.update('8/0/10', afnamepiek)
