17.03.2017, 10:34
Hi is possible to apply the transition only for some object like a widget...???
Transition only for widget
17.03.2017, 10:34
17.03.2017, 10:44
(This post was last modified: 17.03.2017, 10:46 by Erwin van der Zwart.)
Yes you can (: Use this custom css: Code: @-webkit-keyframes Zoom-In /* Safari and Chrome */
0% {opacity:0; -webkit-transform: scale(0);}
50% {-webkit-transform: scale(1);}
100% {opacity: 1;}
#widget-11{
-webkit-animation: Zoom-In 2s !important; /* Safari and Chrome */
-moz-animation: Zoom-In 1s !important; /* Firefox*/
}BR, Erwin
17.03.2017, 12:47
Thank you!!!
I used this custom css to modify the transition of all the widet but it only do when I open the widget. Is there any way to do it when opening and closing? .layer-widget{ -webkit-animation: Zoom-In-Widget 2s !important; /* Safari and Chrome*/ -moz-animation: Zoom-In-Widget 1s !important; /* Firefox*/ } I have tried adding this code in java: $(document.body).on("vclick", function() { $("#widget-112").removeClass("hide"); $("#widget-112").removeClass("ZoomIn"); $("#widget-112").addClass("ZoomOut"); } }); This code close Widget-112 also when i click on the widget. "document.body" is wrong. How can I do it for all open widgets and only when i click out of the widget? Thanks
08.07.2019, 15:33
(17.03.2017, 10:44)Erwin van der Zwart Wrote: Hi, Hi, Is there any way to do the same in both direction (Zoom-in and Zoom-out)? Thanks |
