Transition only for widget
Hi is possible to apply the transition only for some object like a widget...???
Yes you can (:
Use this custom css:
@-webkit-keyframes Zoom-In /* Safari and Chrome */ { 0%   {opacity:0; -webkit-transform: scale(0);} 50%  {-webkit-transform: scale(1);} 100% {opacity: 1;} } #widget-11{ -webkit-animation: Zoom-In 2s !important; /* Safari and Chrome */   -moz-animation: Zoom-In 1s !important; /* Firefox*/     }
Thank you!!!
I used this custom css to modify the transition of all the widet but it only do when I open the widget. Is there any way to do it when opening and closing?
.layer-widget{
-webkit-animation: Zoom-In-Widget 2s !important; /* Safari and Chrome*/
-moz-animation: Zoom-In-Widget 1s !important; /* Firefox*/
I have tried adding this code in java:
$(document.body).on("vclick", function() {
  $("#widget-112").removeClass("hide");
  $("#widget-112").removeClass("ZoomIn");
  $("#widget-112").addClass("ZoomOut");
This code close Widget-112 also when i click on the widget. "document.body" is wrong. How can I do it for all open widgets and only when i click out of the widget?
(17.03.2017, 10:44)Erwin van der Zwart Wrote: Hi,
Yes you can (:
Is there any way to do the same in both direction (Zoom-in and Zoom-out)?
