MQTT Client app
#41
suddenly with today's auto update mqtt client stopped working for multiple instances. Rolling back to older released helped. In error log i can see initialization error for all objects in the rules. It seems i was too naive to have auto update enabled on LM, this update broke critical functionality right in the evening.
What happend with quality control for releases? i don't remember anything like that before.
@myg, an update has been published, see if it fixes the issue for you.
(17.01.2025, 07:54)admin Wrote: @myg, an update has been published, see if it fixes the issue for you.
works again, thank you for quick update
Good morning,
I’m trying to use the Logic Machine 5 Lite for integrating a MQTT payload message.
This is a typically Topic/Payload we receive:
Topic: callway/ad75adfd-b72a-4119-a34c-dfb372df9ecf/status/1/1 QoS: 2
{"data":[{"position":0,"position_type":"room","room":1,"status":"assistance","timestamp":"2025-03-28T10:01:06.000Z","ward":1}],"timestamp":"2025-03-28T11:29:16.000Z","type":"snapshot","uuid":"ad75adfd-b72a-4119-a34c-dfb372df9ecf","version":"1.0.0"}
With this metode I receive on the “String Object” the value: (image 1 and 2)
The problem is that I need to export the value throught Bacnet communication and String object is not permitted.
So, i need to convert the string value into a numeric one, like 06.1 1byte signed integer.
Could you help me with the script ?
Thank you.
Click New Replay then you can attach images
Do you have a define mapping between text and numeric values?
(28.03.2025, 13:02)Daniel Wrote: Click New Replay then you can attach images
i modified the previous message.
Thank you.
(28.03.2025, 13:03)admin Wrote: Do you have a define mapping between text and numeric values?
idle : 0
call: 1
presence: 2
unhooked: 3
assistance: 4
emergency: 5
technical: 6
speech: 7
Remove JSON value path, use this Input script:
local map = {
  idle = 0,
  call = 1,
  presence = 2,
  unhooked = 3,
  assistance = 4,
  emergency = 5,
  technical = 6,
  speech = 7,
local msg = json.pdecode(payload)
if type(msg) == 'table' then
  local status = msg.data[1].status
  return map[ status ]
(28.03.2025, 13:11)admin Wrote: Remove JSON value path, use this Input script:
local map = {
  idle = 0,
  call = 1,
  presence = 2,
  unhooked = 3,
  assistance = 4,
  emergency = 5,
  technical = 6,
  speech = 7,
It works, really thank you.  Cool
Hello, MQTT client app works fine, but it would be nice to be able to edit topics in a texteditor or excel etc? If you have many topics, it is timeconsuming to add them all, or is this something that could be made in a script?
Try this:
data = {
  direction = 'both',
  topic = 'test2',
  address = '0/0/1',
  retain = '1',
  buswrite = '1',
  qospub = '0',
  qossub = '0',
  delta = '',
  throttle = '',
  jsonpath = '',
  boolon = '',
  booloff = '',
dofile('/www/apps/data/mqtt-client/lua/lib.lua')
res = save_topic(data)
log(res)
reload()
thanks. Is there any easy way of implementing timestamp in the script?
Timestamp for what? Explain your task in more detail.
I would like a timestamp as an object in the JSON sendt from LM, can it be done in the script section. i see that "timestamp = os.time()" worked in script.
That returns unix time?
Yes, os.time() returns UNIX timestamp.
