Threads: 5
suddenly with today's auto update mqtt client stopped working for multiple instances. Rolling back to older released helped. In error log i can see initialization error for all objects in the rules. It seems i was too naive to have auto update enabled on LM, this update broke critical functionality right in the evening.
What happend with quality control for releases? i don't remember anything like that before.
Threads: 43
@myg, an update has been published, see if it fixes the issue for you.
Threads: 5
(17.01.2025, 07:54) admin Wrote: @myg, an update has been published, see if it fixes the issue for you.
works again, thank you for quick update
Threads: 0
28.03.2025, 12:59
(This post was last modified: 28.03.2025, 13:02 by Pierluigi .)
Good morning,
I’m trying to use the Logic Machine 5 Lite for integrating a MQTT payload message.
This is a typically Topic/Payload we receive:
Topic: callway/ad75adfd-b72a-4119-a34c-dfb372df9ecf/status/1/1 QoS: 2
{"data":[{"position":0,"position_type":"room","room":1,"status":"assistance","timestamp":"2025-03-28T10:01:06.000Z","ward":1}],"timestamp":"2025-03-28T11:29:16.000Z","type":"snapshot","uuid":"ad75adfd-b72a-4119-a34c-dfb372df9ecf","version":"1.0.0"}
With this metode I receive on the “String Object” the value: (image 1 and 2)
The problem is that I need to export the value throught Bacnet communication and String object is not permitted.
So, i need to convert the string value into a numeric one, like 06.1 1byte signed integer.
Could you help me with the script ?
Thank you.
Threads: 28
Click New Replay then you can attach images
Threads: 43
Do you have a define mapping between text and numeric values?
Threads: 0
28.03.2025, 13:03
(This post was last modified: 28.03.2025, 13:05 by Pierluigi .)
(28.03.2025, 13:02) Daniel Wrote: Click New Replay then you can attach images
i modified the previous message.
Thank you.
(28.03.2025, 13:03) admin Wrote: Do you have a define mapping between text and numeric values?
idle : 0
call: 1
presence: 2
unhooked: 3
assistance: 4
emergency: 5
technical: 6
speech: 7
Threads: 43
Remove JSON value path, use this Input script:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
local map = {
idle =
0 ,
call =
1 ,
presence =
2 ,
unhooked =
3 ,
assistance =
4 ,
emergency =
5 ,
technical =
6 ,
speech =
7 ,
local msg =
json.pdecode (
payload )
if type (
msg ) ==
'table' then
local status =
msg.data [
1 ].
status
return map [
status ]
Threads: 0
(28.03.2025, 13:11) admin Wrote: Remove JSON value path, use this Input script:
local map = {
idle =
0 ,
call =
1 ,
presence =
2 ,
unhooked =
3 ,
assistance =
4 ,
emergency =
5 ,
technical =
6 ,
speech =
7 ,
local msg =
json.pdecode (
payload )
if type (
msg ) ==
'table' then
local status =
msg.data [
1 ].
status
return map [
status ]
end It works, really thank you.
Threads: 65
24.04.2025, 12:09
(This post was last modified: 24.04.2025, 12:10 by tomnord .)
Hello, MQTT client app works fine, but it would be nice to be able to edit topics in a texteditor or excel etc? If you have many topics, it is timeconsuming to add them all, or is this something that could be made in a script?
Threads: 43
Try this:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
data = {
direction =
'both' ,
topic =
'test2' ,
address =
'0/0/1' ,
retain =
'1' ,
buswrite =
'1' ,
qospub =
'0' ,
qossub =
'0' ,
delta =
throttle =
jsonpath =
boolon =
booloff =
dofile (
'/www/apps/data/mqtt-client/lua/lib.lua' )
res =
save_topic (
data )
log (
res )
reload ()
Threads: 65
thanks. Is there any easy way of implementing timestamp in the script?
Threads: 43
Timestamp for what? Explain your task in more detail.
Threads: 65
25.04.2025, 09:47
(This post was last modified: 25.04.2025, 09:50 by tomnord .)
I would like a timestamp as an object in the JSON sendt from LM, can it be done in the script section. i see that "timestamp = os.time()" worked in script.
That returns unix time?
Threads: 43
Yes, os.time() returns UNIX timestamp.
Threads: 65
(24.04.2025, 12:25) admin Wrote: Try this:
data = {
direction =
'both' ,
topic =
'test2' ,
address =
'0/0/1' ,
retain =
'1' ,
buswrite =
'1' ,
qospub =
'0' ,
qossub =
'0' ,
delta =
throttle =
jsonpath =
boolon =
booloff =
dofile (
res =
save_topic (
data )
log (
res )
reload ()
Regarding this, any good ideas on how to implement this based on GA names? As far as I can see we need to run the "save_topic" once for each new topic.
Threads: 43
Use tags. You can filter object list using wildcard search and assign tags using mass edit option.
Threads: 60
30.05.2025, 16:07
(This post was last modified: 30.05.2025, 16:14 by jmir .)
I'm trying to use certificates and I get this message:
"Save failed: unable to get local issuer certificate"
I've seen that someone had this same issue... How can it be fixed?
Using MQTT-Explorer and the same certificates it works.
Threads: 43
Threads: 60
Is there any way to use $ caracter in topic name?
I'm trying to use aws and need that topic name start with $aws/....
