Not sending 6byte RGBW value !
Hi everyone!
I am having trouble with sending 6byte RGBW value. I can't send value to it, for example I want to send value #EB00EB to address 1/7/0 , but it gives error.
grp.write('1/7/0', #EB00EB)
You must pass a table as the value for 6-byte RGBW. Each color is in 0..255 range.
grp.write('1/7/0', {
  red = 255,
  blue = 0,
  green = 127,
  white = 127
Standard RGB/RGBW types use numeric values which can be specified in hexadecimal form as 0xRRGGBB or 0xRRGGBBWW respectively.
Thanks Admin. so much !
Hi everyone!
Today I tried the value is 3byte color (3byte format is: 232,600 RGB color). I want to write this value but it does not do #FFA33A to the value 2/7/42
grp.write('2/7/42', { red = 255, green = 163, blue = 58})
Does anyone know why?
Thank you very much everyone!
Unlike the 6 byte that requires a table to be passed is the 3 byte an integer (you can check this by logging the value it reports)
Just use:
grp.write('2/7/42', 0xFFA33A)
 or
r = 255
g = 163
b = 58
rgb = lmcore.hextoint(lmcore.inttohex(r,1) .. lmcore.inttohex(g,1) .. lmcore.inttohex(b,1))
grp.write('2/7/42', rgb)
This should be helpful too: https://kb.logicmachine.net/scripting/rg...gb-3-bytes
