Threads: 97
Please, can anyone help with connecting a Ondilo spa monitor.
Authentication is to difficult for me
Here the api info how to auth:
https://interop.ondilo.com/docs/api/cust...entication
And here's the general api info:
https://interop.ondilo.com/docs/api/customer/v1/
I have a app username and password but i see nothing in the doc how to get access to the api with that user&pwd
Threads: 97
21.10.2020, 17:53
(This post was last modified: 21.10.2020, 18:29 by gjniewenhuijse .)
Ok, i give it a try
my code:
local usr = "my@email.com"
local pwd = "mypwd"
local uri = "https%3A%2F%2Fyour.app.url%2Fauthorize" -- there's no url redirect, so how to handle this
local state = "c7d37ee542c7'" -- random
---------------------------- change nothing after this line -------------------------------
local apiHost = "https://interop.ondilo.com"
local apiUrl = apiHost .. "/api/customer/v1"
local endpointToken = "/oauth2/token"
local endpointAuth = "/oauth2/authorize"
-- init
if not init then
require('socket.http')
require('ltn12')
require('json')
socket.http.TIMEOUT = 5
init = true
function getAuth()
url = apiHost..endpointAuth..'?client_id=customer_api&response_type=code&redirect_uri='..uri..'&scope=api&state='..state
method = "POST"
local response_body = { }
local payload = '{"login":"'..usr..'","password":"'..pwd..'","locale":"nl","proceed":"Authorize"}'
local res, code, response_headers, status = socket.http.request
url = url,
method = method,
headers =
["Accept"] = "application/json",
["Accept-Charset"] = "utf-8",
["Accept-Encoding"] = "gzip-deflate",
["Content-Type"] = "application/json",
["Content-Length"] = payload:len()
source = ltn12.source.string(payload),
sink = ltn12.sink.table(response_body)
log(res, code, response_headers, status)
log(response_body)
getAuth()
My return:
* arg: 1
* number: 1
* arg: 2
* number: 200
* arg: 3
* table:
["server"]
* string: Apache/2.4.29 (Ubuntu)
["content-type"]
* string: text/html;charset=UTF-8
["connection"]
* string: close
["access-control-allow-methods"]
* string: GET, POST, PUT, PATCH, DELETE, OPTIONS
["access-control-allow-headers"]
* string: X-Requested-With, Content-Type, Accept, Origin, Authorization
["cache-control"]
* string: no-store, no-cache, must-revalidate, max-age=0, post-check=0, pre-check=0
["pragma"]
* string: no-cache
["content-length"]
* string: 4047
["date"]
* string: Wed, 21 Oct 2020 17:45:44 GMT
["vary"]
* string: Accept-Encoding
["access-control-allow-origin"]
* string:
["access-control-allow-credentials"]
* string: true
* arg: 4
* string: HTTP/1.1 200 OK
but how to get the code that is normally send to the url given in the var uri (see above) or is my code wrong?
documentation is here:
if i do the same in a browser, my return url looks like:
https://your.app.url/authorize?code=6440...a88c&state =
c7 d3 7 ee54 2c 7
Threads: 43
What do you get in response body? You should also remove Accept-Encoding header otherwise body will be compressed with gzip instead of plain text.
Threads: 97
(22.10.2020, 06:30) admin Wrote: What do you get in response body? You should also remove Accept-Encoding header otherwise body will be compressed with gzip instead of plain text.
I see the plain website, i think the form is not filled and executed. But how to do this.
same source as:
https://interop.ondilo.com/oauth2/author...d44ef532c5
* table:
[1]
* string:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8"/>
<title>Ondilo authorization page</title>
<style>
margin: 10px 4px 10px 4px;
.box {
width: 340px;
margin: auto;
border: 1px solid rgb(41, 165, 155);
.banner {
margin: 0px;
background-color: rgb(41, 165, 155);
height: 50px;
position: relative;
.ico {
position: absolute;
top: 3px;
left: 4px;
.ondilo {
position: absolute;
top: -1px;
right: 4px;
strong {
margin: 0px;
label {
margin-top: 8px;
margin-bottom: 0px;
display: block;
font-size: 0.8em;
color: gray;
input, select {
font-size: 1.2em;
input[type=text], input[type=password], select {
width: 312px;
input[type=submit] {
width: 322px;
display: block;
margin-bottom: 25px;
.authorize {
color: white;
margin-bottom: 10px;
margin-top: 25px;
border-color: rgb(41, 165, 155);
p {
text-align: center;
margin-top: 25px;
.warning p, .warning ul {
margin: 0 0 0 0;
line-height: 15px;
</style>
</head>
<body>
<div class="box">
<div class="banner">
<img src="/images/ico.png" alt="ICO" title="ICO" class="ico"/
[2]
* string: >
<img src="/images/ondilo.png" alt="Ondilo" title="Ondilo" class="ondilo"/>
</div>
<form method="post">
<p>Sign in to allow <strong>customer_api</strong> to connect to your <strong>Ondilo</strong> account and access the related data</p>
<label for="login">Your email address</label><input type="text" name="login" ><br/>
<label for="pasword">Your password</label><input type="password" name="password">
<label for="locale">Your language</label><select id="locale" name="locale">
<option value="en">English</option>
<option value="fr">Français</option>
<option value="es">Español</option>
<option value="de">Deutsch</option>
<option value="pt">Português</option>
<option value="nl">Nederlands</option>
<option value="it">Italiano</option>
<option value="cs">Čeština</option>
<option value="hu">Magyar</option>
<option value="sv">Svenska</option>
<option value="ro">Română</option>
</select>
<div class="warning">
<p>
We remind that ICO takes measures every hour.</br>
In order to avoid excessive load of our servers, the requests to the Ondilo Customer API are limited to the following per user quotas :
<ul>
<li>5 requests per second</li>
<li>30 requests per hour</li>
</ul>
</p>
</div>
<input type="submit" name="proceed" value="Authorize" class="authorize">
<input type="submit" name="proceed" value="Cancel">
</form>
</div>
</body>
</html>
Threads: 43
For auth you need to use standard POST, not JSON:
function encodepost(t)
local res = {}
local esc = require('socket.url').escape
for k, v in pairs(t) do
res[ #res + 1 ] = esc(k) .. '=' .. esc(v)
return table.concat(res, '&')
payload = encodepost({
login = usr,
password = pwd,
locale = "nl",
proceed = "Authorize",
For this request Accept/Content-Type headers are not needed. Add
redirect = false to the request table to catch the redirect URL instead of following it.
Threads: 97
(22.10.2020, 07:14) admin Wrote: For auth you need to use standard POST, not JSON:
For this request Accept/Content-Type headers are not needed. Add redirect = false to the request table to catch the redirect URL instead of following it.
mmm same result with changed code
function getAuth()
local res = {}
method = "POST"
local response_body = {}
local payload = encodepost({
login = usr,
password = pwd,
locale = "nl",
url = url,
method = method,
redirect = false,
headers =
["Content-Length"] = #payload
if res and code == 200 then
log(response_body)
Threads: 43
Header is missing:
["Content-Type"] = "application/x-www-form-urlencoded"
Threads: 97
(22.10.2020, 08:23) admin Wrote: Header is missing:
yes, now i get the authorization code (authCode).
Next is exchaging the authorization code for an access token, see my code try below.
Doc:
https://interop.ondilo.com/docs/api/cust...n-exchange
-- exchange the authorization code for an access token
if authCode then
url = apiHost..endpointToken..'?code='..authCode..'&grant_type=authorization_code&client_id=customer_api&redirect_uri='..uri
method = "POST"
url = url,
method = method,
headers =
source = ltn12.source.string(''),
but as usually i received an error
* arg: 1
* number: 1
* arg: 2
* number: 400
* arg: 3
* table:
["server"]
["content-type"]
* string: application/json
["connection"]
* string: close
["cache-control"]
["pragma"]
* string: no-cache
["date"]
* string: Thu, 22 Oct 2020 11:14:32 GMT
["content-length"]
* string: 97
* string: *
* string: true
* arg: 4
* string: HTTP/1.1 400 Bad Request
Threads: 43
You must provide "Content-Length" header for POST requests. Move your GET variables to POST payload:
code = authCode,
grant_type = 'authorization_code',
client_id = 'customer_api',
redirect_uri = uri,
Threads: 97
22.10.2020, 16:43
(This post was last modified: 23.10.2020, 06:39 by gjniewenhuijse .)
many thanks to admin for the support.
here my first version to get the latest sensor readings for one pool/spa.
Access tokens have a lifetime of one hour, while refresh tokens are non-expiring.
Threads: 43
One small improvement, you should use the whole table instead of only the first element. If the JSON response is large enough then the response table will have more than 1 element. Use this instead:
data = json.decode(table.concat(response_body))
Threads: 2
Hello
Could you give some instructions with examples how to get sensors data please
I am not familiar with scripting, but can multiply solution from example.
Thank you
Threads: 43
First you need to set usr and pwd variables in the script. Then run this function to get the ID of your pool:
log( getPoolInfo() )
Then you can request the sensor state by calling getSensorInfo:
data = getSensorInfo()
log(data)
When the data format is known the script can be modified to write sensor state to objects.
Threads: 2
(24.05.2021, 09:38) admin Wrote: First you need to set usr and pwd variables in the script. Then run this function to get the ID of your pool:
log(data)
Hello
I have got sensors data, thank you, could you make example of a function for the PUT method?
Thank you
Threads: 43
PUT is the same as POST, just change the method field accordingly
Threads: 3
12.06.2025, 10:51
(This post was last modified: 12.06.2025, 11:15 by function .)
I know that this question is quite some time later than the last post, but is this code still usable or is the API changed? I got respons 419 when getAuth() is triggered.
Respons_body:
* table:
[1]
* string: <!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>Page Expired</title>
<style>
/*! normalize.css v8.0.1 | MIT License | github.com/necolas/normalize.css */html{line-height:1.15;-webkit-text-size-adjust:100%}body{margin:0}a{background-color:transparent}code{font-family:monospace,monospace;font-size:1em}[hidden]{display:none}html{font-family:system-ui,-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Helvetica Neue,Arial,Noto Sans,sans-serif,Apple Color Emoji,Segoe UI Emoji,Segoe UI Symbol,Noto Color Emoji;line-height:1.5}*,:after,:before{box-sizing:border-box;border:0 solid #e2e8f0}a{color:inherit;text-decoration:inherit}code{font-family:Menlo,Monaco,Consolas,Liberation Mono,Courier New,monospace}svg,video{display:block;vertical-align:middle}video{max-width:100%;height:auto}.bg-white{--bg-opacity:1;background-color:#fff;background-color:rgba(255,255,255,var(--bg-opacity))}.bg-gray-100{--bg-opacity:1;background-color:#f7fafc;background-color:rgba(247,250,252,var(--bg-opacity))}.border-gray-200{--border-opacity:1;border-color:#edf2f7;border-color:rgba(237,242,247,var(--border-opacity))}.border-gray-400{--border-opacity:1;border-color:#cbd5e0;border-color:rgba(203,213,224,var(--border-opacity))}.border-t{border-top-width:1px}.border-r{border-right-width:1px}.flex{display:flex}.grid{display:grid}.hidden{display:none}.items-center{align-items:center}.justify-center{justify-content:center}.font-semibold{font-weight:600}.h-5{height:1.25rem}.h-8{height:2rem}.h-16{height:4rem}.text-sm{font-size:.875rem}.text-lg{font-size:1.125rem}.leading-7{line-height:1.75rem}.mx-auto{margin-left:auto;margin-right:auto}.ml-1{margin-left:.25rem}.mt-2{margin-top:.5rem}.mr-2{margin-right:.5rem}.ml-2{margin-left:.5rem}.mt-4{margin-top:1rem}.ml-4{margin-left:1rem}.mt-8{margin-top:2rem}.ml-12{margin-left:3rem}.-mt-px{margin-top:-1px}.max-w-xl{max-width:36rem}.max-w-6xl{max-width:72rem}.min-h-screen{min-height:100vh}.overflow-hidden{overflow:hidden}.p-6{padding:1.5rem}.py-4{padding-top:1rem;padding-bottom:1rem}.px-4{padding-left:1rem;padding-right:1rem}.px-6{padding-left:1.5rem;padding-right:1.5rem}.pt-8{padding-top:2rem}.fixed{position:fixed}.relative{position:relative}.top-0{top:0}.right-0{right:0}.shadow{box-shadow:0 1px 3px 0 rgba(0,0,0,.1),0 1px 2px 0 rgba(0,0,0,.06)}.text-center{text-align:center}.text-gray-200{--text-opacity:1;color:#edf2f7;color:rgba(237,242,247,var(--text-opacity))}.text-gray-300{--text-opacity:1;color:#e2e8f0;color:rgba(226,232,240,var(--text-opacity))}.text-gray-400{--text-opacity:1;color:#cbd5e0;color:rgba(203,213,224,var(--text-opacity))}.text-gray-500{--text-opacity:1;color:#a0aec0;color:rgba(160,174,192,var(--text-opacity))}.text-gray-600{--text-opacity:1;color:#718096;color:rgba(113,128,150,var(--text-opacity))}.text-gray-700{--text-opacity:1;color:#4a5568;color:rgba(74,85,104,var(--text-opacity))}.text-gray-900{--text-opacity:1;color:#1a202c;color:rgba(26,32,44,var(--text-opacity))}.uppercase{text-transform:uppercase}.underline{text-decoration:underline}.antialiased{-webkit-font-smoothing:antialiased;-moz-osx-font-smoothing:grayscale}.tracking-wider{letter-spacing:.05em}.w-5{width:1.25rem}.w-8{width:2rem}.w-auto{width:auto}.grid-cols-1{grid-template-columns:repeat(1,minmax(0,1fr))}@-webkit-keyframes spin{0%{transform:rotate(0deg)}to{transform:rotate(1turn)}}@keyframes spin{0%{transform:rotate(0deg)}to{transform:rotate(1turn)}}@-webkit-keyframes ping{0%{transform:scale(1);opacity:1}75%,to{transform:scale(2);opacity:0}}@keyframes ping{0%{transform:scale(1);opacity:1}75%,to{transform:scale(2);opacity:0}}@-webkit-keyframes pulse{0%,to{opacity:1}50%{opacity:.5}}@keyframes pulse{0%,to{opacity:1}50%{opacity:.5}}@-webkit-keyframes bounce{0%,to{transform:translateY(-25%);-webkit-animation-timing-function:cubic-bezier(.8,0,1,1);animation-timing-function:cubic-bezier(.8,0,1,1)}50%{transform:translateY(0);-webkit-animation-timing-function:cubic-bezier(0,0,.2,1);animation-timing-function:cubic-bezier(0,0,.2,1)}}@keyframes bounce{0%,to{transform:translateY(-25%);-webkit-animation-timing-function:cubic-bezier(.8,0,1,1);animation-timing-function:cubic-bezier(.8,0,1,1)}50%{transform:translateY(0);-webkit-animation-timing-function:cubic-bezier(0,0,.2,1);animation-timing-function:cubic-bezier(0,0,.2,1)}}@media (min-width:640px){.sm\:rounded-lg{border-radius:.5rem}.sm\:block{display:block}.sm\:items-center{align-items:center}.sm\:justify-start{justify-content:flex-start}.sm\:justify-between{justify-content:space-between}.sm\:h-20{height:5rem}.sm\:ml-0{margin-left:0}.sm\:px-6{padding-left:1.5rem;padding-right:1.5rem}.sm\:pt-0{padding-top:0}.sm\:text-left{text-align:left}.sm\:text-right{text-align:right}}@media (min-width:768px){.md\:border-t-0{border-top-width:0}.md\:border-l{border-left-width:1px}.md\:grid-cols-2{grid-template-columns:repeat(2,minmax(0,1fr))}}@media (min-width:1024px){.lg\:px-8{padding-left:2rem;padding-right:2rem}}@media (prefers-color-scheme:dark){.dark\:bg-gray-800{--bg-opacity:1;background-color:#2d3748;background-color:rgba(45,55,72,var(--bg-opacity))}.dark\:bg-gray-900{--bg-opacity:1;background-color:#1a202c;background-color:rgba(26,32,44,var(--bg-opacity))}.dark\:border-gray-700{--border-opacity:1;border-color:#4a5568;border-color:rgba(74,85,104,var(--border-opacity))}.dark\:text-white{--text-opacity:1;color:#fff;color:rgba(255,255,255,var(--text-opacity))}.dark\:text-gray-400{--text-opacity:1;color:#cbd5e0;color:rgba(203,213,224,var(--text-opacity))}}
</style>
<style>
body {
font-family: ui-sans-serif, system-ui, -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, "Helvetica Neue", Arial, "Noto Sans", sans-serif, "Apple Color Emoji", "Segoe UI Emoji", "Segoe UI Symbol", "Noto Color Emoji";
</style>
</head>
<body class="antialiased">
<div class="relative flex items-top justify-center min-h-screen bg-gray-100 dark:bg-gray-900 sm:items-center sm:pt-0">
<div class="max-w-xl mx-auto sm:px-6 lg:px-8">
<div class="flex items-center pt-8 sm:justify-start sm:pt-0">
<div class="px-4 text-lg text-gray-500 border-r border-gray-400 tracking-wider">
419 </div>
<div class="ml-4 text-lg text-gray-500 uppercase tracking-wider">
Page Expired </div>
</div>
</div>
</div>
</body>
</html>
Threads: 97
Threads: 43
Try this as a starting point to get the token:
function getAuth()
local url = apiHost..endpointAuth..'?client_id=customer_api&response_type=code&redirect_uri='..uri..'&scope=api&state='..state
local resp, code, hdrs, stat = socket.http.request(url)
local formtoken = resp:match('name="_token" value="([^"]+)">')
local cookies = hdrs['set-cookie'] or ''
local cookietoken = cookies:match('XSRF%-TOKEN=[^;]+') or ''
local cookiesession = cookies:match('interop_new_api_session=[^;]+') or ''
local escape = require('socket.url').escape
local data = {
'_token=' .. formtoken,
'email=' .. escape(usr),
'password=' .. escape(pwd),
'locale=en',
'proceed=Authorize'
local body = table.concat(data, '&')
local resp, code, hdrs, stat = socket.http.request({
url = url,
method = 'POST',
headers = {
['Content-Type'] = 'application/x-www-form-urlencoded',
['Content-Length'] = #body,
['Referer'] = url,
['Cookie'] = cookietoken .. '; ' .. cookiesession,
body = body
log(resp)
log(code)
log(hdrs)
Threads: 3
Yesterday , 18:03
(This post was last modified: Yesterday , 18:14 by function .)
Thank you!
Threads: 97
If there is a working version, please let it know.
