Zigbee integration
Which Zigbee dongle works on LM5 ?
(07.12.2024, 08:03)Alexander Wrote: Hi,
Hi Alexander,
I suggest to use the usb key or the ZigBee to 232 products (Openrb products)
Best regards Cristian
https://openrb.com/zigbee-rs232-gateway/
Can the ZigBee RS232 also be used on a Wiser (LM5 lite)?
And what would be the route/website to obtain, living in Netherlands.
Looking at range.  When the gateway is in good range of 1 of the zigbee devices, the mesh network of Zigbee itself wil work for devices outside the range of the gateway?
Or is the gateway so strong (inside building)?
Thx for the answers!
SE has its own version of Zigbee interface based on our version but there are some changes so you better get this one for full compatibility. Search for LSS100400
If you add mains powered repeater then the range will be extended beyond the range of the coordinator. Nearly every mains powder zigbee device acts as a repeater.
Hi Alexander,
Hi Cristian,
I’m using the RS-232 Zigbee interface with the Zigbee app on LogicMachine, but not all datapoints from the Zigbee device are showing up. Only some clusters or attributes seem to be available. Do you have any experience with this?
Alexander
This is a list of supported devices https://kb.logicmachine.net/misc/zigbee-devices/
If you device is there then it should have majority of features created. If not then it needs a profile. In any case we never create 100% of features of a device as there is far too many.
(30.06.2025, 11:05)Daniel Wrote: This is a list of supported devices https://kb.logicmachine.net/misc/zigbee-devices/
Hi Daniel,
It looks like my device is on that list – the Amina S Charger. I'm trying to find the specific datapoint shown in the attached image.
I found this on the following page: Amina Zigbee
Share the Device information from the zigbee app of this device(in text format)
(Yesterday, 07:37)Daniel Wrote: Share the Device information from the zigbee app of this device(in text format)
Here it is
.txt   aminazigbee.txt (Size: 873 bytes / Downloads: 1)
OK thanks, we will look at it in a couple of days.
(Yesterday, 08:04)Daniel Wrote: OK thanks, we will look at it in a couple of days.
Thank you Smile
You should be able to read this values via script
https://forum.logicmachine.net/showthrea...e#pid38422
https://kb.logicmachine.net/libraries/zi...wattribute
(Yesterday, 09:56)Daniel Wrote: You should be able to read this values via script
Does this work with older LM5 Lite (newest firmware)? I have this Zigbee gateway from openRb with RS232 communication.
