27.03.2017, 16:26
Hello
I have a problem with two group addresses that I use in conjunction with some scripts to show a text of time and date, these two groups I have defined them as objects of 255 bytes (with 14bytes I do not have enough) and even I use the grpupdate and not the Grpwrite ETS 5 gives me an error each time the resident script is run, I have solved it using an IP filter> TP from these groups but I would like to know if what I am doing is fine or there is another way to do it.
Thank you very much.
