(02.07.2025, 08:51)Daniel Wrote: Share device information from both versions.
Here are the product profiles with the 2 different versions and here is also a copy of my script
local zb = require('applibs.zigbee')
-- Liste des thermostats Zigbee
local thermostats = {
{ name = "TH Atelier – TEST", addr = "7cc6b6fffe0ad6c5" },
{ name = "TH Atelier N°1", addr = "70ac08fffe06bdfb" },
{ name = "TH Atelier N°2", addr = "dc8e95fffe0f8e74" },
{ name = "TH Atelier N°3", addr = "70ac08fffe06aaa5" },
{ name = "TH Accueil Volvo", addr = "7cc6b6fffe0ad8ce" },
{ name = "TH Bureau chef d'atelier", addr = "7cc6b6fffe0acac" },
{ name = "TH Stock pneus", addr = "70ac08fffe06ad6c" },
{ name = "TH5 Thermostat Réfectoire atelier", addr = "048727fffe35b3df" }
-- Cluster Thermostat
local cluster = 0x0201
local attrs = { 0x0000, 0x0011, 0x0012, 0x001C }
-- Lecture des attributs pour un thermostat
local function read_thermostat(th)
print("\n--- Lecture pour : " .. th.name .. " ---")
local success, res_or_err = pcall(function()
return zb.cmdsync('getattributes', th.addr, cluster, attrs)
end)
if success then
local res, err = res_or_err, nil
if res then
print("Attributs récupérés :")
for attr_id, value in pairs(res) do
if attr_id == 0x0000 or attr_id == 0x0011 or attr_id == 0x0012 then
print(string.format(" Attribut ID 0x%04X : %.2f °C", attr_id, value / 100))
elseif attr_id == 0x001C then
print(string.format(" Attribut ID 0x%04X : Mode système = %d", attr_id, value))
print(string.format(" Attribut ID 0x%04X : %s", attr_id, tostring(value)))
print(" [!] Aucun attribut reçu – passage au thermostat suivant.")
print(" [!] Erreur lors de la requête : " .. tostring(res_or_err))
-- Boucle principale
for _, th in ipairs(thermostats) do
read_thermostat(th)
Manufacturer: Schneider Electric
Model: S520619
Firmware version: 001.000.053
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- HvacThermostat (513)
- HvacUserInterfaceCfg (516)
- HaDiagnostic (2821)
- ManuSpecificWiserEvent (65027)
- ManuSpecificCycleTime (65302)
- ManuSpecificHeatingCooling (65315)
Output clusters
- Identify (3)
- Time (10)
- Ota (25)
- MsTemperatureMeasurement (1026)
- MsOccupancySensing (1030)
Endpoint 2
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
Output clusters
- Identify (3)
Endpoint 4
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
Output clusters
- Identify (3)
Endpoint 5
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- SeMetering (1794)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- currentsummdelivered: 0
- heatingstatus: true
- localtemperature: 25.64
- occupiedcoolingsetpoint: 20.00
- occupiedheatingsetpoint: 18.00
- picoolingdemand: 0
- piheatingdemand: 0
- seopenwindowstatus: false
- sepowerdivisor: 1000
- sepowermultiplier: 1
- systemmode: 4
Model: S520619
Firmware version: 001.000.071
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
Output clusters
- Identify (3)
- Time (10)
- Ota (25)
Endpoint 2
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
Output clusters
- Identify (3)
Endpoint 4
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
Output clusters
- Identify (3)
Endpoint 5
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- SeMetering (1794)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- heatingstatus: false
- localtemperature: 27.96
- occupiedheatingsetpoint: 19.00
- systemmode: 0
