Modbus master - connect failed
I've a W4k, which I want to use as modbus master and slave.
With the IP .128 W4k is a modbus slave. The script for this workes fine.
With the IP .129 W4K should be a modbus master. I've created and imported a modbus profile. The objects of this profiles are mapped as well.
Any idea why the connect failes?
Looks like you are try to connect master to itself. Is the device you want to connect to Modbus TCP or RTU?
