how to sort the names listed ?
Hi all,
How can we sort the names listed on the left side under the widget ?
For example in alphabetical order ?
It is very difficult for me to find the widget like this.
Is there a solution for this?
Thank you for your helps.
its ok on "Vis. Structure"..
But its not ok "visualization"
This will be fixed in the next firmware.
Meanwhile you can run this script to fix the sort order.
function sort(itype)
  local query = 'SELECT id, name FROM visfloors WHERE type=?'
  local items = db:getall(query, itype)
  table.sort(items, function(a, b)
    return a.name < b.name
  end)
  for i, item in ipairs(items) do
    db:update('visfloors', { sortorder = i }, { id = item.id })
sort('widget')
sort('layout')
(21.08.2025, 07:13)admin Wrote: This will be fixed in the next firmware.
  end)
sort('widget')
sort('layout')
Its ok !
Thank you a lot.
