NTP Client Details
I am using LM as NTP Server to sync Date & Time of connected NTP clients. I need a script to log NTP data exchange details from any device configured as NTP client and connected to the LM NTP server.
There is are available scripts in the forum, but they are used for logging the NTP data exchange between LM as NTP client and a remote NTP server.
Thanks,
Chouaibou.
Disable both NTP server and client in system config. Create a resident script with sleep time set to 5 seconds. You can replace region (europe) with 2-letter country code (de, fr, etc) for more precise time updates.
reg = 'europe' cmd = '/usr/sbin/ntpd -ddd -l -n -p 0.%s.pool.ntp.org -p 1.%s.pool.ntp.org -p 2.%s.pool.ntp.org -p 3.%s.pool.ntp.org 2>&1' cmd = string.format(cmd, reg, reg, reg, reg) proc = io.popen(cmd) while true do   line = proc:read()   if line then     if line:find('responded to query from') then       ip = line:match('%d+%.%d+%.%d+%.%d+')       log('NTP query', ip)     end   else     break   end end proc:close()
(30.09.2025, 08:22)admin Wrote: Disable both NTP server and client in system config. Create a resident script with sleep time set to 5 seconds. You can replace region (europe) with 2-letter country code (de, fr, etc) for more precise time updates.
Hi admin,
Many thanks!
I will test the script and give feedback
Hi admin,
Many thanks!
Hi admin,
The script is working fine. The LM is not actually connected to the internet.
I am using my Laptop NTP server.
Thanks!
Below the logs:
LM_As_NTP_Server_Debugger 30.09.2025 12:00:35
* string: ntpd: sending query to 10.195.221.101
* string: ntpd: reply from 10.195.221.101: offset:+0.000217 delay:0.002551 status:0x24 strat:1 refid:0x4c434f4c rootdelay:0.000000 reach:0x7f
* string: ntpd: update from:10.195.221.101 offset:+0.000217 delay:0.002551 jitter:0.002000 clock drift:+0.329ppm tc:5
* string: ntpd: poll:32s sockets:1 interval:32s
LM
Hi admin,
Please do we have any compatibilty matrix file of SNTP and NTP versions (Client /Server)?
It seams like it is important for the Client / Server to work properly.
Thanks!
LM NTP client/server operates at version 4 by default. But replying to clients with older versions is also possible. What NTP clients are you using?
If you want precise time you should allow LM to synchronize with a real NTP server. Internal LM clock is not guaranteed to be accurate enough for long time periods.
(01.10.2025, 08:48)admin Wrote: LM NTP client/server operates at version 4 by default. But replying to clients with older versions is also possible. What NTP clients are you using?
Hi admin,
Thank you for your reply.
I am using NTP Cient version 4.
Can LM NTP client synchronizes with a server with an SNTP protocol? Or is it mandatory for both to support same Network Time Protocol NTP or SNTP?
Thanks!
It should work with SNTP too. Use this script to check the connection: https://forum.logicmachine.net/showthrea...3#pid31293
(01.10.2025, 12:14)admin Wrote: It should work with SNTP too. Use this script to check the connection: https://forum.logicmachine.net/showthrea...3#pid31293
Thank you admin or sharing the link.
I will use it to check the connection.
