Make sure that LM has valid gateway and DNS settings in System config > Network > Interfaces > eth0.
See if you can ping remote.logicmachine.net from System config > Status > Network utilities.
03.10.2025, 10:28 (This post was last modified: 03.10.2025, 10:29 by Nir70.)
(01.10.2025, 07:18)admin Wrote: Make sure that LM has valid gateway and DNS settings in System config > Network > Interfaces > eth0.
Yesterday, 09:38 (This post was last modified: Yesterday, 09:59 by Nir70.)
(Yesterday, 06:32)Nir70 Wrote:
(03.10.2025, 10:58)Daniel Wrote: Ping remote.logicmachine.net or 168.119.164.110
hi i get ping attached
Thanks, the problem is solved. I disabled the firewall And the connection was made & synchronization i turned the firewall back on router and then still connected . Thanks for all the advice, best regards
