05.05.2025, 08:02
Morning i'm trying to send Email
i followed the steps in the manuel attached, but i can't send email
email sending
05.05.2025, 08:02
05.05.2025, 08:48
Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911
05.05.2025, 08:55
Are you using gmail? If yes did you created an app password in your gmail account and use that in your script?
(05.05.2025, 08:48)Daniel Wrote: Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911This is what i have from log Code: * arg: 1
* nil
* arg: 2
* string: 535-5.7.8 Username and Password not accepted. For more information, go to
535 5.7.8 https://support.google.com/mail/?p=BadCredentials 4fb4d7f45d1cf-5fa77bf1e35sm8035646a12.66 - gsmtpThis is the function i used : Code: function Email(to, subject, message)
---------------BEGINNING OF USER EDITABLE AREA-------------------
local settings = {
from = 'nguenangulrich6@gmail.com',
-- smtp username
user = 'nguenangulrich6@gmail.com',
-- smtp password
password = '***',
-- smtp server
server = 'smtp.gmail.com',
-- smtp server port
port = 465,
secure = 'sslv23',
-------------------END OF USER EDITABLE AREA---------------------
local escape = function(v)
return '<' .. tostring(v) .. '>'
-- message headers and body
headers = {
to = escape(to),
subject = subject,
body = message
-- fixup from field
settings.from = escape(settings.from)
settings.rcpt = { escape(to) }
return smtp.send(settings)
endthe gmail acount i created is "nguenangulrich6@gmail.com" and the pasword "***" (05.05.2025, 08:55)Erwin van der Zwart Wrote: Are you using gmail? If yes did you created an app password in your gmail account and use that in your script? Yes, like in the above message
07.05.2025, 13:32
You need to enable 2FA and the create app password: https://myaccount.google.com/apppasswords
When adding password to your script remove all spaces so only 16 characters are left.
07.05.2025, 16:37
(06.05.2025, 16:51)Fistel Wrote:Thank's, it's OK now(05.05.2025, 08:48)Daniel Wrote: Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911This is what i have from log
27.11.2025, 11:25
Morning to everyone,
I tryed to do the same script, in my Comm Funct, I have: Code: function mail(to, subject, message)
local settings = {
from ='al*******@gmail.com',
-- smtp username
user = 'LM********',
-- smtp password
password = '********',
-- smtp server
-- smtp server port
port = 465,
-- secure = 'tlsv1_2',
secure = 'sslv23'
return '<'..tostring..'>'
-- if type(to) ~= 'table' then
-- to = { to }
--end
-- for index, email in ipairs(to) do
-- to[ index ] = '<' .. tostring(email) .. '>'
--end
-- Fixup from field
-- local from = '<' ..tostring(settings.from)..'>'
headers = {
-- to = table.concat(to, ', '),
to = escape(to),
subject = subject,
--['From'] = settings.from,
['From'] = from,
['Content-type'] = 'text/html; charset=utf-8',
body = message
-- fixup from field
--settings.from = '<' .. tostring(settings.from) .. '>'
-- settings.from = from
--settings.rcpt = to
settings.rcpt = { escape(to)}
endAnd in my Event-Script I have: Code: curr_value = event.getvalue()
prev_value = storage.get('prev_value')
if curr_value == prev_value then
return
storage.set('prev_value', curr_value)
os.sleep(10)
if curr_value then
subject = 'Main switch = PERMIT'
message = '\nState: Desbloqueado'
subject = 'Main switch = PROHIBIT'
message = '\nState: BLOQUEADO!!'
mail('ju*********@gmail.com', subject, message)The problem is that when I Run my Event script, I don't have any Log or Error, but I neither recive any e-mail in my account. I will appreciate the help!
27.11.2025, 11:32
Use this to get the result/error in Logs tab.
Code: res, err = mail('ju*********@gmail.com', subject, message)
log(res, err)Don't randomly change the mail() function. You only need to change the settings table, everything else should be kept as is. In your case the 'From' header is invalid because the assigned variable is not defined.
27.11.2025, 11:52
(27.11.2025, 11:32)admin Wrote: Use this to get the result/error in Logs tab. Thanks for the point. I forgot to include the log, but when I run the script again, I get no response from either the log or the error log, even though I added the log before running it. I'm also not receiving the email. I've also removed the "From" from the message body, so it now looks like this (in Comm Func) : Code: function mail(to, subject, message)
local settings = {
from ='al************@gmail.com',
-- smtp username
user = 'LM**********',
-- smtp password
password = 's************',
-- smtp server
-- smtp server port
port = 465,
secure = 'sslv23'
return '<' .. tostring .. '>'
headers = {
to = escape(to),
subject = subject,
body = message
27.11.2025, 11:55
From header is required, mail sending won't work without it. Temporarily modify the event script so it only sends the email without checking the previous value and waiting for 10 seconds.
27.11.2025, 12:08
(27.11.2025, 11:55)admin Wrote: From header is required, mail sending won't work without it. Temporarily modify the event script so it only sends the email without checking the previous value and waiting for 10 seconds. Almost fixed, now it's sending me the same error that the collegue: Quote: * string: 535-5.7.8 Username and Password not accepted. For more information I already change the user name and the password, I delete the spaces from the password and give the same name that I use when i create the app password, the "app name"
27.11.2025, 12:18
Username should be the same as the sending email (from), including @gmail.com
The app password should be 16 characters without spaces.
27.11.2025, 12:20
