Zigbee gateway integration
(18.12.2025, 08:58)admin Wrote: Check this: https://kb.logicmachine.net/libraries/zi...-attribute
For Voltage/Current/Power the formula is value * Multiplier / Divisor. In most cases multiplier and divisor are fixed values.
Thank you. I've tried:
local res, err = zb.cmd('getnamedattribute', address, 'SeMetering', 'CurrentSummDelivered')
But the result from that is:
string: 21024-1
Which is not very useful to convert to integer. I've also tried other combinations to get current temperature, temperature setpoint and so on, but I get the same formatted string as a result every time. err is always nil.
he Zigbee gateway does not work after a network outage and shows an error message:
lua: /tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:191: ...tmp.mtkFYYoRG4/files/store/daemon/zigbee/zigbee/core.lua:979: ZB: could not start coordinator
stack traceback:
[C]: in function 'error'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:191: in function 'task_resume'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:204: in function 'callback'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:158: in function 'task_timer_run'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:39: in function 'run'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/app.lua:493: in main chunk
[C]: at 0x00014afc
Try rebooting LM. If this will not help try powering down all zigbee routers(all mains powered devices) and reboot again.
What are the LEDs says?
(Yesterday, 09:25)Daniel Wrote: Try rebooting LM. If this will not help try powering down all zigbee routers(all mains powered devices) and reboot again.
Hi Daniel,
There is 1 LED on the ZigBee RS232, one red for power.
On the logicmachine there is one green LED flashing and one solid yellow LED for PoE.
I also noticed that inside the logicmachine housing on the RS232 ports side there is a red LED flashing at the same frequency. Restarted the device with no result
Andi
Did you perform the actions I described above?
(Today, 08:53)Daniel Wrote: Did you perform the actions I described above?
Yes, Have I followed all the steps described?
