LM Home app (Andrоid/iOS starter)
Good morning,
Could you please send me the link to download the LM Home App .apk file? It’s for an Android 8.1 device.
I believe this app is only available starting from Android 10? In that case, I will need the link to the other app.
Thank you so much.
Here is the old one, New LM Home is only for android 10+
https://www.transfernow.net/dl/202505224ShvC26z
(22.05.2025, 10:31)Daniel Wrote: Here is the old one, New LM Home is only for android 10+
Thanks!
Hello, everyone! I have some problems with my evening. I'm using a message lmhome. But it's having problems: the notification from Lmhome to the phone has no sound, nor can it be reviewed (no Log section to review) . So my customers complained, there was no warning sound, no review of the notice, so it was very inconvenient. Does somebody have a solution for it ? I'm very much grateful to you for sharing it.
Notification settings are a mobile settings. Nothing we can do here.
We're trying to use the new LM Home app on an ipad ios18.6.2 and when the app opens it goes directly to cloud loggin.
we've tried to hold the icon and go to settings but allways goes to cloud login... If we're not connected to a wifi then we can access to manual configuration but when we enable wifi again it jumps to cloud login...
Thanks, we were able to reproduce this bug, luckily it works on iphone. Unfortunetelly the developer responsible for the app is on holiday for two weeks and we will have to wait for him to get back to fix it. Sorry for the inconvenience. You should be able to use the shortcut for now.
Hello. I'm testing the LM HOME notification service. On my iPhone, the notification is instant, but there's no sound. I checked the settings, and notifications are enabled. However, I can't read the notification in full, as tapping it takes me directly to the Visu. Is it possible to add a tab, which could even be toggled in the view menu, so that a separate notifications section appears and I can see them?
Push notifications are OS based, LM Home app doesn't even know about them. We are planning to add visu notifications at some point.
