Trend widget Y-axis
I noticed a small issue with the Trend widget.
The values on the Y-axis are not displayed with the decimal separator (,) and it is not possible to adjust the number of decimal places for the parameters.
As a result, when hovering over the trend to read recent values, the values appear as 195 and 1925 instead of 19.5 and 19.25, as shown in the attached screenshot.
Can you drop a screenshot of a actual tool-tip? It works for me correct. What settings did you use for this trend in LM trend tab?
(19.01.2026, 09:24)Daniel Wrote: Can you drop a screenshot of a actual tool-tip? It works for me correct.  What settings did you use for this trend in LM trend tab?
Now its woriking fine...
