Adding camera on Visu app
Sorry if you already discussed the mater, but I could not find any guidance on it.
I have an IP camera (HIKVISION), which i would like to see on my Visu app.
I can access the camera through any browser, but when I add it in Visu, I don't get
any picture.
Any idea on what might be wrong?
(24.01.2026, 11:29)Chandrias Wrote: Sorry if you already discussed the mater, but I could not find any guidance on it.
any picture.
Good evening,
Can you show the http string are you using?
Best regards Cristian
any picture.
Good evening,
I tried a few, but with no success.
This (http://192.168.99.182/doc/page/preview.asp) is the one I use to access the camera through my browser
any picture.
Good evening,
Try thisĀ
http://<up cam>:<port>/ISAPI/Streaming/channels/101/picture
Set proxy with your credentials and refresh every 1 sec
working for me: http://IP/ISAPI/Streaming/channels/102/p...Height=320
Resolution should be provided and checked, some HIK cameras not showing stream without resolution in link.
Moments to check:
1. Just not remember, but I think for stream you want to use - MJPEG coding should be used. In my link - 102 means 2nd stream, so check settings for camera's 2nd stream;
2. Select mark "Request snapshot using local proxy and put login and pass for stream you want to use";
3. Put refresh rate not less than 5 seconds. Some time is needed to create picture, some to send it. This is just snapshots and not works in real time. Not forget about load to network/proxy/cloud etc..;
4. Check size of the snapshot - admin told me it should not be over than 1 Mb (Just open picture from visu in new window and save it, check size). At one site I have new 4 MP HIK cameras and some problems because of snapshot is over 1Mb but customer locally need both streams with max quality..
Alex
any picture.
Good evening,
Try thisĀ
The new link works just fine. Thank you.
