Visu bugs
#81
Hi Daniel, specifically the Akuvox S563 Monitor with firmware version 563.30.13.202 Android 12.0 IPS 8"
Add this to Visu Custom JavaScript and post what version is reported by your device.
alert(window.navigator.userAgent)
(02.02.2026, 11:45)admin Wrote: Add this to Visu Custom JavaScript and post what version is reported by your device.
Mozilla/5.0 (Linux; Android 12; rk3566_s Build/SP2A.220305.012.wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/95.0.4638.74 Safari/537.36
New beta version is published, see if it works on your device: https://forum.logicmachine.net/showthrea...1#pid41181
I use a couple of dtp 14.056 4-byte float in Visu.
In the object list on LM, and in Visu/Visu admin on pc the values are correct.
In LM Home cloud app on my iPhone the values are strange. Values shown in the app changes from small to large both negative and positive values.
The correct values shown on PC changes from 100 to 1400. Never negative values.
Edit:
I deleted the two "numeric value display widgets" and added them again.
Seems like it's ok nowSmile
Hello, in version 20260319 (beta) the plan link buttons disappear from the screen when accessing 'visu' directly with the local URL; from the LM Home application they are displayed correctly.
We cannot recreate this issue, please send me your backup to PM and explain where to look for.
@davidchispas, new beta build has been posted, try it Smile
(23.03.2026, 13:46)admin Wrote: @davidchispas, new beta build has been posted, try it Smile
It worked! Thank you so much!
I get 403 error for a user that should have access to a page in visu. Login works. Is the latest beta version but also was there with the stable version.
Post a screenshot of general access settings for this user.
(27.03.2026, 10:14)admin Wrote: Post a screenshot of general access settings for this user.
[Image: ZwrQUm.jpg]
And in VISU only the room that is allowed to control is marked.
Visu is an app and you should give access to it in apps
(27.03.2026, 14:53)Daniel Wrote: Visu is an app and you should give access to it in apps
Tnx it’s fixed
Maybe I'm doing something wrong!
I have added a Numeric value display, Object is 09.001
I have added 3 Additional values/icons
-30-0
1-19
20-50
With 3 different icons
But the icons never shows! Is it because the value is 19.70°C?
Yes as you created a gap, do it like that,
-30-0
0-20
20-50
(09.04.2026, 10:23)Daniel Wrote: Yes as you created a gap, do it like that,
-30-0
0-20
20-50
Thank you
