Custom JavaScript examples
(24.07.2024, 06:32)admin Wrote: Check this: https://forum.logicmachine.net/showthrea...2#pid17512
I would like to implement a haptic feedbak using Visualization on iPhone or Android phones.
Is this pssible with a custom java script?
Thanks and kind regards, Daniel
See this: https://developer.mozilla.org/en-US/docs...ration_API
It will only work on Android, Safari on iOS does not support this API.
Hello.
I have a variable that tells me there are new alerts ‘true’.
I would like that when I access the screen where I see the alerts, that variable automatically changes to ‘false’.
Can anyone help me?
Thank you.
What kind of variable? It is a group address?
A virtual bool one; 50/1/0
See this: https://forum.logicmachine.net/showthrea...3#pid21463
Something like this, keeping in mind that the screen ID is 112 and the variable is 50/1/0:
$(function(){
if (typeof grp == 'undefined') {
return;
$('body').on('showplan', function(event, id) {
if (id == 112) {
grp.write('50/1/0', 0);
}).trigger('showplan', [ currentPlanId ]);
Hi, I've tried the code and it's not working. Could someone help me with this? Thanks in advance.
Which Visualization tool do you use?
(11.02.2026, 12:32)Daniel Wrote: Which Visualization tool do you use?
PC/Tablet
Change script to this, open browser dev tools (F12) and check what you get in the console. Are you sure that the target plan ID is 112?
$(function(){
    return;
  console.log('custom js initialized');
    console.log('changed to plan', id);
    if (id == 112) {
When testing this will work from end visualisation not editor.
Yes, panel ID is 112
And yes, I try it on end visualisation. Still not working.
I have a schnider wiser, I don't know if it is a problem.
See my previous post, check browser console. Does 50/1/0 exist? Do you have anything else in Custom JS?
Your script works for me on SL, if it doesn't work then it is wrong ID or group.
I have a 50/1/0 address that tells me there are new alerts. The idea I have in mind is that when I access the alerts panel, that variable automatically changes to 0, so that it is assumed that there are no new alerts.
CSS is not JavaScript, check manuals where is the correct place.
(11.02.2026, 13:52)Daniel Wrote: CSS is not JavaScript, check manuals where is the correct place.
Yes, you are absolutely right.
My mistake, I just tested it and the code works correctly.
Thank you very much.
