custom values in visu
what is the better way to see the custom values in new Visu ? (I see the number value and not the custom )
Alberto
KNX Advanced Partner + Tutor
Additional values/icons in Visu is the same what Custom values are LM. If you set a object on the witget you will be able to load custom values to visu if they are set.
Now I undertand
I must change it here
and not here
As I mentioned above, if you define them under objects, you can load them to visu widget but first you must select the object in visu widget.
