NetworX (Interlogic) Gateway
I am trying to implement a LM to a NetworkX NX-8E alarm panel gateway and i need some help creating the basic serial over IP comunication script as i haven't any experience with serial protocols.
If someone else has implement something relative and could help it would bu much appreciated.
Networx RS-232 Gateway Interface Protocol
Thank you in advance
George
Any luck with this topic?
I've a meter with a P1 port(=serial). To read the data is use this:
lastchar = '!'
require('serial')
port = serial.open('/dev/ttyUSB1', {
  baudrate = 115200,             --DSMR 2/3 = 9600        DSMR 4 = 115200
  databits = 8,                    --DSMR 2/3 = 7            DSMR 4 = 8
  stopbits = 1,                    --DSMR 2/3 = 1            DSMR 4 = 1
  parity = 'none',            --DSMR 2/3 = even        DSMR 4 = none
  duplex = 'full'
function readdata(port)
  local char, buf
  buf = {}
  while true do
    char = port:read(1)
    -- error (timeout) or newline, stop
    if char == nil or char == lastchar then
      break
    -- ignore cr char
    elseif char ~= '\r' then
      table.insert(buf, char)
  return table.concat(buf)
data = readdata(port)
port:flush()
if data then
  AphA = data:match'31.7.0%((%d+.%d+)'
  AphA = tonumber(AphA)
  grp.update('32/1/74', AphA)
-- "more code"
