scripting knx
Good morning,
I'm having a problem with the functions and I don't know how to solve it.
Here's the problem:
I currently have three logic machines taking KNX data from temperature, humidity, and CO2 sensors. I need them to calculate the average temperature, CO2, and humidity. But I only want to calculate this for the sensors located in rented properties.
I have the following variables.
Rented or non-rented status of 27 dwellings in group addresses from 2/0/176 to 2/0/202:
- Rented = 1
- Non-rented = 0
Temperature values delivered by each dwelling sensor:
'0/0/11','0/0/27','0/0/43','0/0/59','0/0/75','0/0/91','0/0/107',
'0/0/123','0/0/139','0/0/155','0/0/171','0/0/187','0/0/203',
'0/0/219','0/0/235','0/0/251',
'0/1/11','0/1/27','0/1/43','0/1/59','0/1/75','0/1/91','0/1/107',
'0/1/123','0/1/139','0/1/155','0/1/171'
Variable where the average building temperature will be stored:
2/0/164
And now I'll show you the code I wrote:
-- Direcciones de estado de las 27 viviendas (0=libre, 1=alquilada, 2=mantenimiento, 3=ocupada)
local estados = {}
for i = 1, 27 do
    estados[i] = '2/0/' .. (175 + i)  -- 176 → 202
-- Direcciones de temperatura individuales
local direcciones_temp = {
-- Dirección donde guardar la temperatura media
local destino1 = '2/0/164'
-- Rango válido de temperaturas
local min_temp = -20
local max_temp = 60
-- Intervalo de espera: 5 minutos (300 segundos)
local INTERVALO = 300
-- BUCLE PRINCIPAL (TU MISMO CÓDIGO, REPITIÉNDOSE PARA SIEMPRE)
while true do
    local suma = 0
    local contador = 0
    -- Recorrer las 27 viviendas
    for i = 1, 27 do
        local estado = grp.getvalue(estados[i])
        local valor = grp.getvalue(direcciones_temp[i])
        -- Solo usar temperatura si la vivienda está alquilada
        if estado == 1 then
            if valor ~= nil and type(valor) == "number" then
                if valor >= min_temp and valor <= max_temp then
                    suma = suma + valor
                    contador = contador + 1
                    log("Temperatura fuera de rango en " .. direcciones_temp[i] .. ": " .. tostring(valor))
                log("Valor de temperatura inválido o nulo en " .. direcciones_temp[i])
    -- Guardar la media si hay datos válidos
    if contador > 0 then
        local media = suma / contador
        grp.write(destino1, media)
        log("Temperatura media (solo alquilados) actualizada en " .. destino1 .. ": " .. media)
        log("No hay viviendas alquiladas con temperatura válida para calcular la media")
    -- Esperar 5 minutos antes de repetir
    os.sleep(INTERVALO)
Lo he intentado por todos los medios posibles y no me  calcula la temperatura media y cuando lo hace satura la memoria de la logic machine.
What script type are you using? The correct approach is to use a scheduled script that runs every 5 minutes and remove the while loop and os.sleep at the end.
What is the data type of rented status object. Is it boolean or 1 byte?
Buenas tardes,
Estaba ocupado con la construcción. Adjunto fotos del tipo de datos utilizado para los estados de las propiedades; es la versión 7.2.
En cuanto al script, se trata de un script basado en eventos.
It can't be an event script. Make a scheduled script as suggested earlier.
I haven't tried yet to create scripts scheduled at specific times and dates; I'm worried that the code won't understand that it needs to update the average temperature every 5 or 10 minutes.
