Blink Output LM5R
I need a digital output from the reactor that makes a lamp flash. Is it possible to create a reusable function that does this, passing it the flashing time?
Thank you very much.
Resident script, get value and write back 'not value'
Add to Common functions:
function blink(event, addr, delay)   local obj = grp.find(addr)   if not event.getvalue() then     obj:write(false)     return   end     local value = obj.value   while true do     value = not value     obj:write(value)     os.sleep(delay)   end end
Create a boolean object and map an event script to it. Set Execution mode to "Last instance only".
0/0/2 is the output control group address.
3 is delay in seconds between each on/off.
blink(event, '0/0/2', 3)
Writing true to the event script object will start the blinking. Writing false will stop it and will turn the output off.
