3 hours ago
We have a client who has several LMs spread across different installations.
Using the new visualization and to control them from the Cloud, is there a way to see them all and choose which one to access?
We did a test by putting 2 of them in the same network but when accessing the cloud (both from the web and from the LM Home app) by default it enters one of them and we do not see a way to change to the other.
We also did the test by creating 2 networks and in this case a menu appears to select which network to access from the bottom of the side menu in the visualization. Is this the only way to switch between them?
What is the difference between creating two networks or putting two devices in the same one?
