KNX 19.001 datatype
I`m trying to write time and date to a group adress with datatype 19.001. Have been looking in the example: http://openrb.com/example-write-lm2-data...addresses/
but can`t really see there how I`m supposed to Write the actually value to the Group adress. (I`m really new at this Undecided )
Can you help me?
-Kristian
(19.04.2019, 19:58)KristianSl Wrote: Hi
Can you help me?
-Kristian
Use the code below and modify as needed
-- get current data as table now = os.date('*t') -- system week day starts from sunday, convert it to knx format wday = now.wday == 1 and 7 or now.wday - 1 -- time table time = { day = wday, hour = now.hour, minute = now.min, second = now.sec, } -- date table date = { day = now.day, month = now.month, year = now.year, } --- full date bits OCT08 = now.year - 1900 OCT07 = now.month OCT06 = now.day OCT05 = bit.bor(bit.lshift(wday, 5), now.hour) OCT04 = now.min OCT03 = now.sec OCT02 = 0 -- subfields like working day and dst not specified in this sample OCT01 = 0 -- subfields like quality of clock not specified in this sample -- write to bus date_time = string.char(OCT08) .. string.char(OCT07) .. string.char(OCT06) .. string.char(OCT05) .. string.char(OCT04) .. string.char(OCT03)  .. string.char(OCT02)  .. string.char(OCT01) grp.write('Date', date, dt.date) grp.write('Time', time, dt.time) grp.write('DateTime', date_time)
Can you help me?
-Kristian
Smile thanks
ello,
It doesn't work for me when I have to write down a datetime (DPT 19.001).
I only get the result:
RawDpValue
00 00 00 00 00 00 00 00
Can anyone try to help me please?
My code is,
function setDateTime(obj)
  now = os.date('*t')
-- time table
  time = {
  day = wday,
  hour = now.hour,
  minute = now.min,
  second = now.sec,
  -- date table
  date = {
  day = now.day,
  month = now.month,
  year = now.year,
  --- full date bits
  OCT07 = now.month
  OCT06 = now.day
  OCT04 = now.min
  OCT03 = now.sec
  log (OCT08,OCT07,OCT06,OCT05,OCT04,OCT03,OCT02,OCT01)
  -- write to bus
grp.write(obj, date_time)
I used your script without the function and it works.
  -- get current data as table   now = os.date('*t')   -- system week day starts from sunday, convert it to knx format   wday = now.wday == 1 and 7 or now.wday - 1 -- time table   time = {   day = wday,   hour = now.hour,   minute = now.min,   second = now.sec,   }   -- date table   date = {   day = now.day,   month = now.month,   year = now.year,   }   --- full date bits   OCT08 = now.year - 1900   OCT07 = now.month   OCT06 = now.day   OCT05 = bit.bor(bit.lshift(wday, 5), now.hour)   OCT04 = now.min   OCT03 = now.sec   OCT02 = 0 -- subfields like working day and dst not specified in this sample   OCT01 = 0 -- subfields like quality of clock not specified in this sample   log (OCT08,OCT07,OCT06,OCT05,OCT04,OCT03,OCT02,OCT01)   -- write to bus   date_time = string.char(OCT08) .. string.char(OCT07) .. string.char(OCT06) .. string.char(OCT05) .. string.char(OCT04) .. string.char(OCT03)  .. string.char(OCT02)  .. string.char(OCT01) grp.write('date test2', date_time)
Can it be a problem because my language-settings Swedish?
Try specifying datatype explicitly:
grp.write(obj, date_time, dt.string)
(19.12.2019, 14:55)admin Wrote: Try specifying datatype explicitly:
When I specify with dt.string, the result been type of
16.001 Character String (ISO 8859-1)
And nothing saves/writes into '2/0/0'
Log:
Loggad vid 19.12.2019 16:18:04
* arg: 1
  * number: 119
* arg: 2
  * number: 12
* arg: 3
  * number: 19
* arg: 4
  * number: 144
* arg: 5
  * number: 18
* arg: 6
  * number: 4
* arg: 7
  * number: 0
* arg: 8
  * number: 0
You should use the 250 byte object for this..
(19.12.2019, 15:34)Erwin van der Zwart Wrote: Hi,
Yes, but how?
BR Alex
Yes, but how?
BR Alex
The object you writing to must be 250 byte string.  The real values you will see only in ETS group monitor
Yes, but how?
BR Alex
I trying to write to this:
Like this, with script I posted
(19.12.2019, 16:09)Daniel. Wrote: Like this, with script I posted
Thank you SmileSmile
Now its works Smile
Is there a datetime widget in Visu?
At the moment only separate Date and Time widgets are supported.
