Widget Iframe change URL Dinamycally
Hello!
I have a widget with iframe inside with external URL.
I want this URL to be direct link trendlog but I want to change this URL depending of the button pressed.
Is this possible? Or do I have to make one widget for each URL?
Thanks!
You can do this via Custom JavaScript, change #widget-2 to your widget's id, create buttons as needed and set Additional classes to btn-1, btn-2 and so on.
$(function() {
  function seturl(url) {
    $('#widget-2 iframe').prop('src', url);
  $('.btn-1').off('vclick').on('vclick', function() {
    seturl('https://forum.logicmachine.net');
  $('.btn-2').off('vclick').on('vclick', function() {
    seturl('http://openrb.com');
Lot of thanks!
$(function() {
  $('.btn-1').on('vclick', function() {
  $('.btn-2').on('vclick', function() {
Modified code for my use!
Which is the event to trigger On/Off the Widget?
Use this to emulate click on the button that opens/closes widget:
$('.widget-btn').trigger('vclick')
Thanks Admin!!
