Passage from one HK/LM to another
I would like to know if there is a simple way to switch from viewing one HomeLynk / LM to another without nesting the visualization of the other but really opening up the visualization of the second HK / LM.
Use this as custom javascript on object bit 1/1/1 in both controllers:
1234567891011121314
$(function() {   if (typeof grp != 'undefined') {      grp.listen('1/1/1', function(object, state) {          var value = object.value;          if (state == 'value') {             if (value == 0) {               $(location).attr('href', 'http://admin:admin@192.168.0.10/scada-vis');             } else {               $(location).attr('href', 'http://admin:admin@192.168.0.11/scada-vis');                }          }       }, true);     } });
Make sure both controllers have this custom javascript, the object 1/1/1 and can communicate over KNX IP or KNX TP so object value will be always the same in both controllers
Hi Erwin,
Very good.
