Download lat&long from LM
is it possible to download the latitude and longitude from LM in lua to use it in apps?
These variables can be nil if no latitude/longitude is set:
<? require('apps') config = getconfig() write(config.latitude, ', ', config.longitude)
I've tried to use it in Resident script (of course without <?) but it returns below error:
Resident script:2: attempt to call global 'getconfig' (a nil value)
stack traceback:
I've used your solution and now I send get request to .lp file but interesting thing is that I must fill also login and password when I try to connect localhost(this is from demo machine):
http = require "socket.http" result = http.request("http://admin:admin@127.0.0.1/user/long&lat.lp") longitude, latitude = result:match('(%d*.%d*),(%d*.%d*)') longitude, latitude = tonumber(longitude), tonumber(latitude) log(longitude, latitude)
From scripts you can use:
require('uci') lat = uci.get('genohm-scada.core.latitude') lat = tonumber(lat) lng = uci.get('genohm-scada.core.longitude') lng = tonumber(lng)
For sure this is much more easier solution, and last solution was little complicated. Is this also for deamon scripts?
This will work anywhere, in apps as well.
