18.09.2017, 09:57
is it possible to download the latitude and longitude from LM in lua to use it in apps?
Download lat&long from LM
18.09.2017, 09:57
18.09.2017, 10:31
These variables can be nil if no latitude/longitude is set:
Code: <?
I've tried to use it in Resident script (of course without <?) but it returns below error:
Resident script:2: attempt to call global 'getconfig' (a nil value) stack traceback: I've used your solution and now I send get request to .lp file but interesting thing is that I must fill also login and password when I try to connect localhost(this is from demo machine): Code: http = require "socket.http"
20.09.2017, 12:49
From scripts you can use:
Code: require('uci')
For sure this is much more easier solution, and last solution was little complicated. Is this also for deamon scripts?
20.09.2017, 14:27
This will work anywhere, in apps as well.
