2 byte to 1 byte
How do i take a 2 byte signal(9.009) and convert it to a 1 byte signal(5.001).
Need to use the 2 byte signal in a formula up against 1 byte signal and can not figure out how to proceed here.  Undecided
thank's for any help! Smile
That depends on what you want to do, what information do you need from the 2 byte value to the 1 byte value?
Could be something like this:
twobytevalue = event.getvalue() onebytevalue = math.floor((twobytevalue / 256) + 0.5) grp.write('1/1/2', onebytevalue)
Or:
twobytevalue = event.getvalue() if twobytevalue < 255 then   onebytevalue = math.floor(twobytevalue + 0.5) -- round airflow to integer else   onebytevalue = 255 -- if airflow is higher then 255 then max is reached end grp.write('1/1/2', onebytevalue)
