mqtt client
Hi, anyone got a working example on how to connect to mqtt broker in local network?
How should broker ip,port be set?
I can`t find any examples on how to do this. The broker has been tested and from nodered i can publish to it.
-John
1234567891011121314151617181920
mqtt = require("mosquitto") client = mqtt.new() client.ON_CONNECT = function()        client:publish("world", "hello")        local qos = 1        local retain = true  local mid = client:publish("lm/test/1", "my payload", qos, retain) end client.ON_PUBLISH = function() client:disconnect() end broker = 10.85.0.4:1883 client:login_set("user","password") client:connect(broker) client:loop_forever()
Like this, port is optional and defaults to 1883:
broker = '10.85.0.4'
If you need to set a custom port then pass it as a second parameter to connect:
client:connect('10.85.0.4', 12345)
