Script_Disable: strange behaviour
script.disable('Valvola_Bagno_Giorno_Automatismo')
termostato_giorno = event.getvalue()
os.sleep(0.2)
if termostato_giorno == true then
 grp.write('2/0/8', true) -- valvola bagno giorno
os.sleep(10)
script.enable('Valvola_Bagno_Giorno_Automatismo')
script.disable('Valvola Bagno Notte Automatismo')
termostato_notte = event.getvalue()
os.sleep(0.2)
if termostato_notte == true then
  grp.write('2/0/5', true) -- indirizzo valvola bagno notte
os.sleep(5)
script.enable('Valvola Bagno Notte Automatismo')
Hi above 2 event based script which works but in the first case script anable and disable does not work. I mean that does not disable the script ('Valvola_Bagno_Giorno_Automatismo'). The name of the script is correct.
I cannot the reason why in the second script I see the resident script ('Valvola Bagno Notte Automatismo') which change its status. In the other case no.
I cannot understand the reason why.
Are you sure that the name is correct? In one place you have name with spaces, in another with "_". You can also do this:
log(script.disable('Valvola_Bagno_Giorno_Automatismo'))
If logged value is nil it means that script is not found.
Yes, I used "_" because at the beginning there's not. I copied the name of the script and paste it. The same thing I did with the working script.
In any case I check.
I log the variable.
The first time was bool:false, the second time I test it value was nil. How is it possible?
