[Bug report] event scripts execution
Script 1
grp.write('1/0/0', true) grp.write('1/0/1', true)
Script event '1/0/0'
log('1/0/0')
Script event '1/0/1'
log('1/0/1')
What I do:
 Run Script 1.
What I see in log: (first script running only)
 string '1/0/0'
What should be in log: (all scripts running)
 string '1/0/0'
 string '1/0/1'
lHi,
Well i’m pretty sure there is no bug otherwise we would known this for sure as your sample is used on every project.
Are you sure you have enabled all your scripts? (press F5 to refresh to be sure), are your objects both boolean? Are there errors in the error tab?
As http://4n.lv:7999/ doesn't work and I've left that house where bug is presented I can't tell you details until monday. Sorry.
Is object 1/0/1 defined in your project? Write will not work if data type is not known.
Thank you for help.
I had troubles with logic inside script.
Admin can delete thread because of my mistake.
